Old 04-02-2011, 08:28 PM   #1
Problem with water barrier under 2011 8280ws
Hey ya'll got a question for ya. I noticed on our new Rockwood 8280ws that the material under the RV has separated from the frame it has what looks like aluminum moulding that forms a bracket to support the hard plastic material that forms the underbelly of the unit.
I see only one spot in the drivers side corner just behind the rear axle where it looks like a screw has bee pulled through. Just wondering if anyone has had this happen and possibly a fix. I don't want to take it anywhere like this because the way it looks it could catch air and maybe pull completly off, taking the grey water dump and lord knows what else with it.
gparrow is offline   Reply With Quote
Old 04-02-2011, 11:23 PM   #2
Iggy's Avatar
Just install a self tapping sheet metal screw where the one is gone.
No big deal. That plastic is just to keep the big stuff and water from getting under the frame.
Old 04-02-2011, 11:31 PM   #3
grhodes50's Avatar
You could also add a large washer to keep the new screw from pulling through the enlarged hole.
Gary & Trish
2018 Nights Camped - 5
Old 04-03-2011, 06:35 AM   #4
jimh's Avatar
my underbelly came loose on my trailer and i did as above: screw and fender washer. has held for last 8 yrs.
jimh is offline   Reply With Quote
Old 04-03-2011, 06:45 AM   #5
DAISY BOYKIN's Avatar
Screw pulled loose
Most of the screws are screwed into a wood strip that is attached to the frame. There are plenty of extra holes along the metal retaining strip on the 8285WS. Just add more screws in the empty holes or make a new hole right beside the enlarged existing hole. Sheet metal screws with square hole in the head is available at LOWES/HOME DEPOT. Where you need to
replace or add screws to the plastic only, make sure the screw has deep threads and a large head to support the plastic.
But be careful if you are adding or replacing screws in the plastic only, make sure your screws are not too long.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
280, 8280ws
