Old 12-05-2011, 07:07 PM   #1
propane detector buzz
Has anyone ever had a high pitched noise coming from their propane leak detector located just to the right of the fuse and converter panel ? I have a almost new Rockwood 2604 (slightly used, traded in a keystone bullet 250rks) both are 2011 models. I must say that I like the 2604 much better, even spent last saturday afternoon sitting in it watching the college football game. Wife says its my man cave! Anyway I hear this high pitch, but not over the tv or radio.
Reiner is offline   Reply With Quote
Old 12-05-2011, 07:12 PM   #2
Boyd's Avatar
This sounds serious! Go out to your propane tank, turn off the propane and see if the buzz continues....NOW!
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 12-05-2011, 07:22 PM   #3
Low battery voltage will set it off. Are you plugged in to shore power? Is your battery charged and showing full charge on the monitor panel?
Do be careful, it may be for real.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 12-05-2011, 08:33 PM   #4
propane is off. hooked to shore power, charge in battery good.
any more ideas
Old 12-05-2011, 08:35 PM   #5
I dont think it is actually going off. Just a high buzz sound. some cant hear it but i can.
Old 12-05-2011, 08:42 PM   #6
I do have everything off, propane,tv,radio,mic,heat,air,lights. Had to put my ear right down and beside it befor I was sure of where it was coming from. Pushed the test button, it worked fine, but still the high buzz. Thanks Boyd and Windrider
Old 12-05-2011, 10:26 PM   #7
Bill_C's Avatar
The propane detector buzz is a common thread. High pitched and annoying if you can hear it. I can't hear it, my daughter says it drives her nuts. It is a bad detector. Replace it and all will be well.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 12-06-2011, 06:07 AM   #8
Thanks Bill C, I will look into having it replaced. I think I will first pull it out and disconnect it from the power source to make sure that is the problem. Tell your daughter that it also drives me to insanity but my wife saye"what noise".
Reiner
Old 12-06-2011, 09:39 AM   #9
tom50mg's Avatar
This summer I sprayed a little lysol air freshener around and had the detector go off for a while...it,s great they are this sensitive!
tom50mg is offline   Reply With Quote
Old 12-06-2011, 10:27 AM   #10
Rugged Brown's Avatar
Batteries low in your hearing aid??? Just a thought.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
