Old 01-02-2016, 01:05 PM   #11
Some of these have been mentioned. Does the oven light? Does the refer operate on propane? Is there propane in the tank(s)? Does the 'empty' indicator show red? If so, flip to the second tank and then does the indicator show green? Is the second tank turned on? Has the OPD been activated?
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 01-02-2016, 01:07 PM   #12
daveclark's Avatar
Thanks for all the advice. All other propane appliances work fine. I suspect a good cleaning of the grill is in order. I'll clean it when we get home tomorrow and check it out more thoroughly. I've got a campfire to tend to!
Dave (daveclark) with Carol (Carolclark) and Timmy the Bichon in
"Roxy" the 2016 Rockwood Signature Ultralite 8299BS pulled by
2016 Ford F-350 Powerstroke Platinum 4x4 Crew Cab
8 Nights Camping in 2015
9 Nights Camping in 2016
daveclark is offline   Reply With Quote
Old 01-02-2016, 01:51 PM   #13
Brother Les's Avatar
Mine has a shut off at the quick disconnect on the unit. Did you shut the off and forgot?
Brother Les
Old 01-03-2016, 08:36 AM   #14
BillyBass's Avatar
I had the same problem when I had my pop up But I had a small flame took a hr to boil water when i pick up the hose the flame got bigger,. So I change the quick connect then everything was ok
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites 2018 2 nites
2015 16 nites
BillyBass is online now   Reply With Quote
Old 01-03-2016, 08:54 AM   #15
Flybob's Avatar
Spiders are attracted to the chemical added to propane to make it smell. Try using compressed air to reverse blow out the grill parts.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-03-2016, 10:29 AM   #16
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Toddupton View Post
The quick connect should have a check valve in it take a pen or something like that and press in on the check valve to see if you smell gas. I have had a bad nipple that would not depress the check valve.
Due to the sudden onset of the malfunction, this has my vote. I'm betting the hose was pushed far enough onto the nipple to hold, but not far enough to open the check valve.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-03-2016, 10:40 AM   #17
Left Coast
Loosen hose at grill and smell
propane
