Old 01-01-2016, 12:01 PM   #1
daveclark's Avatar
Propane grill quit working
Well it only took a month for the propane grill that attaches to the outside to quit working. Of course high winds and cold were on hand, but I had charcoal so we still ate burgers and used the grill to put over the rusted park grill.
Since it uses the quick connects and I own nothing else with these, how can I test that it's the grill and not the line on the RV? I've triple-quadruple checked connections and nothing, it worked great last week...
Dave (daveclark) with Carol (Carolclark) and Timmy the Bichon in
"Roxy" the 2016 Rockwood Signature Ultralite 8299BS pulled by
2016 Ford F-350 Powerstroke Platinum 4x4 Crew Cab
8 Nights Camping in 2015
9 Nights Camping in 2016
daveclark is offline   Reply With Quote
Old 01-01-2016, 12:11 PM   #2
Left Coast
Crack open connection at grill and see if you can smell propane..the threaded end
Old 01-01-2016, 12:26 PM   #3
daveclark's Avatar
Ah yeah will try that when we get home. Dutch oven meals and weenie roasts are on the menu from here on anyways.
Old 01-01-2016, 12:40 PM   #4
Left Coast
Also, if no stink, work your back toward bottle(s).....be aware, the bottle pig-tails have a one way valve inside that's not servicable....inside stove ok?
Old 01-01-2016, 03:48 PM   #5
Ambassador
Ken K.'s Avatar
Well for starters, did you hear gas coming out before you tried lighting it? Was the gas on? Was the cut off on the quick connect turned on? Check the burner tube make sure the vent holes are free and open. Not the holes flames come out of, but the air mixing vent near where the gas passes through the pan of the grill
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 01-02-2016, 12:01 PM   #6
gectisme's Avatar
If you have gas and it is like mine, make sure your piezo igniter connections and itself are good too (or you can try a match).
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 01-02-2016, 12:46 PM   #7
Try lighting with a clicker flame fire starter
Harkerr is offline   Reply With Quote
Old 01-02-2016, 12:59 PM   #8
CC75's Avatar
So the propane tank has an OPD valve. The design of the OPD valve is that turning the cylinder service valve handwheel will not produce any effect if the cylinder is not hooked up to an appliance. Couple of times, on my home grill there was no propane coming out of the tank, even though the tank was full, and properly connected. Turning the valve off at the tank fixed the problem. I once had to disconnect the regulator and screw in back onto the tank, and everything was OK afterwards. I suppose it was a sticky valve. I have since replaced the tank, and no problems since
CC75 is offline   Reply With Quote
Old 01-02-2016, 01:01 PM   #9
The quick connect should have a check valve in it take a pen or something like that and press in on the check valve to see if you smell gas. I have had a bad nipple that would not depress the check valve.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 01-02-2016, 02:04 PM   #10
I had the same problem. I took the BBQ grille guts completely apart, took a wire brush and scraped every opening. Tested it out before putting it back together and it all worked fine.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 01-02-2016, 02:05 PM   #11
Some of these have been mentioned. Does the oven light? Does the refer operate on propane? Is there propane in the tank(s)? Does the 'empty' indicator show red? If so, flip to the second tank and then does the indicator show green? Is the second tank turned on? Has the OPD been activated?
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 01-02-2016, 02:07 PM   #12
daveclark's Avatar
Thanks for all the advice. All other propane appliances work fine. I suspect a good cleaning of the grill is in order. I'll clean it when we get home tomorrow and check it out more thoroughly. I've got a campfire to tend to!
Old 01-02-2016, 02:51 PM   #13
Brother Les's Avatar
Mine has a shut off at the quick disconnect on the unit. Did you shut the off and forgot?
Brother Les
Old 01-03-2016, 09:36 AM   #14
BillyBass's Avatar
I had the same problem when I had my pop up But I had a small flame took a hr to boil water when i pick up the hose the flame got bigger,. So I change the quick connect then everything was ok
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 01-03-2016, 09:54 AM   #15
Flybob's Avatar
Spiders are attracted to the chemical added to propane to make it smell. Try using compressed air to reverse blow out the grill parts.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-03-2016, 11:29 AM   #16
AKA: 'tiredTeacher
awellis3's Avatar
Due to the sudden onset of the malfunction, this has my vote. I'm betting the hose was pushed far enough onto the nipple to hold, but not far enough to open the check valve.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-03-2016, 11:40 AM   #17
Left Coast
Loosen hose at grill and smell
propane
