Forest River Forums
Sunline User Photos
Old 11-27-2010, 08:23 AM   #1
mgargiullo's Avatar
Pur Water Filter in the 8316 vs. 4 screws
I have a 2010 Rockwood 8316ss. I absolutely love this TT. We upgrading at the beginning of this year from a 1988 Sunline. When we picked up the TT I was instructed to put a filter into the water filter's canister which is in a small cabinet under the pantry.
I put the wrench on, visibly check the threads to ensure it's not reverse threaded and then twist. It's on gorilla tight... not a good sign. I used my other hand to hold the top as still as possible, but still managed to torque the whole assembly off the wall instead of opening the container. In the process pulling both of the screws that held the filter canister right out of the thin strip of pine it's mounted to.
I brought it back to the dealership, explained the situation and asked that they 'fix' it. I probably should have been more specific. They put it back up with 4 screws this time and left the canister loose for me. Camping season went well until yesterday when I went to winterize it. I opened the cabinet, placed the wrench on the canister and turned. The bracket twisted and started to pull the screws out again.
Change of plans. I disconnected the water lines from it, unscrewed it and pulled the whole assembly out. After pouring the water out, I attempted to unscrew it using by slipping the top into a padded vise. Even then it took a good deal of muscle to open it.
I'm in the process of building a more substantial bracket that won't twist, but this is crazy. I don't want to have to go through this every time I change a filter or winterize the TT.
Do you have the same issues with your filter canister or do I have one thats a bit off?
2004 Banks Equipped Chevy Suburban 1500
2010 Rockwood Signature 8316SS
2010 Final: 35 nights - Can't wait until April
mgargiullo is offline   Reply With Quote
Old 11-27-2010, 01:11 PM   #2
Lou Amadio
herk7769's Avatar
Yep. Everytime I have had trouble getting the canister body off, I hit my head. (DOH!)
The reason is that, everytime, I had forgotten to get all pressure off the system.
Before trying to remove the canister you MUST...
Remove the outside hose
Turn off the 12 volt pump
and
Open a cold water faucet in the camper to relieve the pressure
Close it (or there will be a lot of water coming off with the filter body)
Spins right off easily everytime.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 11-27-2010, 02:11 PM   #3
bsmall's Avatar
and
Thanks Herk, I printed out your instructions, laminated the paper and placed it near the filter so I will always have it when I need them...
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 11-27-2010, 02:44 PM   #4
Hipshot's Avatar
I have not had problem removing the filter. But when I went to drain it before my trip to Korea in October, I found the 4 screws that hold it to the mount bracked were stripped and it was hanging by the hoses. I have to engineer a fix before our trip to the Texas coast next week. Ain't it fun.
2010 Rockwood 2604SS
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
Old 11-27-2010, 03:19 PM   #5
Moderator
mtnguy's Avatar
Besides letting the pressure off like Lou said, there is another thing to consider. In most campers, you are looking down at the canister. Instead of turning the wrench counter clockwise like you would normally do, you actually need to turn the wrench clockwise, since you are looking at the opposite side of the unit.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is offline   Reply With Quote
Old 11-28-2010, 05:16 PM   #6
mgargiullo's Avatar
I was in the midst of winterizing. I had not only opened all the faucets but had already disconnected the In and Out hoses to the filter body.
I had to remove the whole filter body, turn it upside down in my padded vise and it still took a bunch of muscle to open.
I fixed the flimsy bracket issue by fabricating a new one out of some 1 inch angle iron and some scrap steel I welded into a platform. Drill out the mount holes and better than stock. At least I won't rip the filter off the wall next time I try to change it.
As for how tight it was... I thought I saw a bit of the O-ring in the threads... I guess I'll grab a new one when I order the new filter. We'll see next season.
Old 11-28-2010, 09:22 PM   #7
The Old Man
Willis's Avatar
I always add a little bit of vaseline to lubricate the o-ring. It never comes into contact with the water, but if someone is more squeamish than I, then there are totally non-toxic lubricants available made for kitchen products. But the point is that a dry o-ring may cause the "hard-to-open" issue described above.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 11-28-2010, 11:16 PM   #8
I had one of those filter housings in my 2009 8317SS when I took delivery. No filter? Does anyone know what the filter is?. I just used an inline filter in my incoming water line but I would like to use the filter that came with the trailer. I went back to the selling dealer but he went out of business. Appreiciate any help.
Braidwood is offline   Reply With Quote
Old 11-29-2010, 07:28 AM   #9
Moderator
TheSasks's Avatar
It is not just RV's that these filter housings stick. I have a whole house unit as a prefilter to our conditioning units and it is a bear to get off as well. I make sure the pump is off then open a tap in the RV and then let some water out of the low point drains prior to removing the housing. You can pick up straight 5 micron filter cartridges at Walmart for 5 or 6 bux if memory serves me. I am not sure where to get the carbon type that they come from the factory with.
John & Deb
2008 Dodge Ram 2500 4x4 Laramie Hemi Megacab
2011 Flagstaff V-Lite 30WRLS
TheSasks is offline   Reply With Quote
Old 11-29-2010, 08:16 AM   #10
You should not use Vaseline to lube the o-ring. You need silicon pool lube or 100% silicon food grade lube. Most pool stores carry it in a small tube if you can't find it elsewhere.
Those housings should not have to be tightened to seal. Once the o-ring is on the sealing surface it should seal. Tightening them more is just making it harder on you getting it off.
Grand Surveyor GS-280 Pushing a 2500 Mega-Cab CTD!
WOW it's already 2012! Gotta go campin
8316, pur, rockwood, water filter
Close [X]
