Old 07-10-2010, 07:14 PM   #11
Cardinal 04 31LE
Originally Posted by wakamicamper View Post
Yeah, that's what my antenna looks like. Highest point on the trailer is 13 feet and this is higher still? I must have hit a low branch or something.
Any info on the usage of 2 x 30 lb propane bottles. I will be dry camping for 20 days in August and the closest propane refill centre is 50 miles one way. My wife is worried that we will run out. I carry a spare 20 lb bottle for a bar-b-q that we would use if the others run out.
Thanks for the responses.
I dont dry camp, but I do have 2-30# propane tanks that I fill once a year. I camp about 30 days a year maybe more. Use propane for heat, occassional refridgerator operations, and hot water and some occassional cooking inside. I have not run out yet. In fact I just filled them today one was empty the second was 50%.
I do suggest that you work off one tank at a time, therefore if you run out of the first tank in less than 10 days you will know to reduce consumption. I dont rely on the valve in the camper, I shut the tank off that I don't want to use.
Good Luck
Mr.B is offline   Reply With Quote
Old 07-10-2010, 11:03 PM   #12
Question
Good Luck
Good advice. While camping in June, I noticed the changeover valve was showing red for the RH tank, so I switched over to the LH tank. When I got home I took the tanks off the tongue & got them refilled. I could hear sloshing in the RH tank & the LH tank seemed noticebly heavier.
When I got them filled @ a local truck stop (there's always a person or 2 getting tanks filled), the attendant asked why I was getting them filled as they didn't really take much propane to fill. I said, I wasn't sure about how full they were before I left for camping (trailer had sat on lot for a year & I had been trying out the various systems) & didn't know how much was left.
When I got home, both 20 pound bottles weighed 36 pounds on a digital scale. I guess I'll just have to weigh them to make sure.
About the changeover valve. Is the red indication quite distinct or is it faint? I may have seen a red reflection thru the glass & thought it was red & ready to change. Instructions for the valve are a poor translation from Chinese to English.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 07-11-2010, 11:34 AM   #13
The fridge is pretty efficient- minimal gas usage there. However, the water heater- depending on how thrifty you can be on hot showers and dishes. Also, if you happen to need gas heat for those cool nights, that is a big energy hog, on your battery and your gas. Good luck, Randy
rockwood
