Old 07-09-2010, 06:53 PM   #1
wakamicamper's Avatar
Questions
We have an 2010 8280SS 5th wheel. It has 2 x 30 lb propane bottles. Can anyone tell me how long the propane will last over a season, if you use the propane for both the frig and cooking? (But not the Bar-b-q)
Another question, we have the dinette in the trailer. The seat cushions are continually sliding forward on the bench. We have put an anti-skid matt on top of the plywood to stop the sliding to no avail. Does anyone have an idea on how to prevent the seat cushion from sliding?
I was on the roof the other day and the antenna for the radio is horizontal along the roof. Is it supposed to be standing up (vertical) for not?
The labels on the side of the trailer refer to a "Waste water dump" and a "Sewer dump". In all the info on the trailers, the reference is either black or gray water. So which is the black in this case. My trailer has 2 gray water tanks because of the rear kitchen. The galley gray tank is in the rear with its own dump, and the shower and sink in the bedroom is on a 2nd dump next to the black tank, but I haven't been able to determine which is which.
Thanks in advance for any answers.
2009 GMC Sierra SLT Crew Cab 4x4 Diesel
2010 Rockwood 8280SS
Camping 2012: 40 nights
wakamicamper is offline   Reply With Quote
Old 07-09-2010, 07:17 PM   #2
NWJeeper's Avatar
Use velcro on the seats,
The stero antenna should be vertical
Waste water dump = gray water
Sewer dump = black water
Ed & Wendy
www.nwjeepn.com
Old 07-09-2010, 08:00 PM   #3
To confirm which tank various water comes out of, do the following procedure:
1. Make sure both of your waste tanks are empty and clean to start with.
2. Close both of them.
3. To check the shower, pour a gallon or two of water down the drain. Or run the shower. You only need a small amount to test it.
4. Open up the tank marked waste water. The water from the shower should come out of it. If not, open the tank marked sewer water. If it comes out of that one, then you will be dumping that sewer tank quite often. On some models, the shower is plumbed into the black tank. Not sure why, but they are.
5. Repeat the steps for the bathroom sink, just to see if it is plumbed to the gray tank or the black tank.
Hokiehall is offline   Reply With Quote
Old 07-09-2010, 10:32 PM   #4
Iggy's Avatar
Hokiehall your answer in figuring out what valve is which is to easy and logical.
Old 07-09-2010, 11:46 PM   #5
Dave_Monica's Avatar
The antenna is the same on our 8280WS. I believe that they angle it back as it's on the highest part of the roof for clearance.
Dave
Old 07-10-2010, 10:11 AM   #6
Wanna Be Camper
SaskCampers's Avatar
Ditto
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-10-2010, 10:21 AM   #7
Herk7769's Avatar
Mine always starts out a trip vertical, but the first tree branches/leaves I hit on the way out knocks it flat again.
So,... I leave it down until I get where I am going.
Since I powered up the XM radio I don't use over the air much anymore and it is a moot issue now.
HAM CALLSIGN - KC3FFW
Old 07-10-2010, 10:38 AM   #8
Is this what you're referring to?
There is a locking screw to adjust the angle...depends how many overpasses you want to hit with it.
Dave
Old 07-10-2010, 06:24 PM   #9
Yeah, that's what my antenna looks like. Highest point on the trailer is 13 feet and this is higher still? I must have hit a low branch or something.
Any info on the usage of 2 x 30 lb propane bottles. I will be dry camping for 20 days in August and the closest propane refill centre is 50 miles one way. My wife is worried that we will run out. I carry a spare 20 lb bottle for a bar-b-q that we would use if the others run out.
Thanks for the responses.
Old 07-10-2010, 06:46 PM   #10
NWJeeper's Avatar
With the exception of multi element beam type of antennas usually used for amateur radio or the old style TV antennas you used to see above every house, all antennas are designed to be used in a vertical manner. They will still receive in a horizontal fashion but not as well. Depending on your RV and your situation you might not be able to have the antenna totally vertical. Ours for instance would get wiped out when entering/exiting our garage if it was vertical. For the time being I don't even have it attached. The antenna should be as close to vertical as possible for best reception.
Ed & Wendy
www.nwjeepn.com
rockwood
