Old 10-07-2015, 03:10 PM   #1
Quick connect gas connect to grill outside
No gas coming out, it is all turned on, any ideas?
roaddiva is offline   Reply With Quote
Old 10-07-2015, 03:17 PM   #2
Alleged curmudgeon
Vern's Avatar
Could be anything from the valve on top of your propane tank(a) being turned off, to a wrong or poor connection between your grill and the quick-connect.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 10-07-2015, 03:18 PM   #3
Ugh!!! Poor connection!!
Old 10-07-2015, 03:18 PM   #4
Learning a lot as I go...
I have not really had much trouble with it... the quick connect is a bit stubborn and I would make sure it is all the way on as most have a shut-off feature when disconnected.
And of course you *did* already turn the shut off lever into the on position so that cannot be a problem
Be forewarned that it is NOT the world's greatest BBQ :-p In fact it run a bit on the cool side except in specific spots that run hot. But I have to admit it is convenient and kinda cool to hang it on the side and cook away.
stevejahr is offline   Reply With Quote
Old 10-07-2015, 03:19 PM   #5
Alleged curmudgeon
Vern's Avatar
Does that mean you made the connection and it is now working?
Lee
Old 10-08-2015, 03:11 PM   #6
Yes, it is a tight fit and I didn't have it on all the way. I cooked a pizza, came out great! :-)
Old 10-08-2015, 06:06 PM   #7
Left Coast
Heard the lever on the valve is there to keep people from disconnecting the coupler while being used....think the lever won't let the release release when in line with hose.
Old 10-13-2015, 12:15 PM   #8
Winnipeg,Manitoba-Canada
pdchristensen's Avatar
I find it interesting that there are all the warnings about running the bbq with the awning extended, when in fact that unit runs pretty cool...
2015 Rockwood 2306 MiniLite
2012 Chevy Traverse
2011-2014 - 50 nights
Paul, Darcie, Li & Yan
pdchristensen is offline   Reply With Quote
gas
