Old 03-30-2011, 01:34 PM   #11
KyDan's Avatar
Typically you have to pry off the trim ring around the outside
edge of the unit. This will hopefully pop off with some
convincing from a flat screwdriver or possibly a stiff
putty knife or even a butter knife.
Once the trim ring is off you should see screws to remove.
Then the unit will pull/fall out of the opening.
Be prepared for a birds nest of tangled wires in the rear.
Good luck!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 03-30-2011, 06:33 PM   #12
HogHead
Bauerson's Avatar
pulled the radio, tugged on the speaker wires, they were all good, now the cd/dvd doesnt play. (made sure all those cables were tight in their sockets also) already thinking of upgrading. if thats possible. thanks for the reply. jb
Bauerson is offline   Reply With Quote
Old 03-30-2011, 07:18 PM   #13
ken0042's Avatar
I wouldn't be doing much troubleshooting on my own. You have a brand new unit; let the dealer handle it under warranty. You could also end up voiding your warranty if you cause a further problem.
I know going to the dealer may not always be handy. That's why over the winter I made a list of minor issues, and had my dealer look at them all this month.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 03-31-2011, 06:22 AM   #14
KyDan's Avatar
Post your exact problem in the Concertone forum
found here--
Concertone - Forest River Forums
There is a Concertone rep who monitors that area and
he will hopefully give you some needed help.
The concertone unit is fine once you get it working.
As others have said, it's a warranty issue but I know
how it feels to be miles from the dealer.
Good luck!!
Peace!
Dan & Rita D
Blue Ox WD hitch
