Old 08-09-2019, 04:29 AM   #1
Raining in 2018 2703
Camper stays under cover most of the time. Has not been in rain often, cannot find source of leak. Left it at dealer in rain and they did not see any leak from rain. Water appears in bathroom when it happens. It is positively coming from rain, only happens when raining. 3rd time. Probably happening when new. Rain appears under the side wall in the cabinet under the bathroom sink, and running along the inside bathroom wall under the cabinet. Dealer could not find source of leak. Any help would be appreciated.Click image for larger version
ID:	211891Click image for larger version
ID:	211892Click image for larger version
JoeyL is offline   Reply With Quote
Old 08-09-2019, 06:04 AM   #2
Originally Posted by JoeyL View Post
Camper stays under cover most of the time. Has not been in rain often, cannot find source of leak. Left it at dealer in rain and they did not see any leak from rain. Water appears in bathroom when it happens. It is positively coming from rain, only happens when raining. 3rd time. Probably happening when new. Rain appears under the side wall in the cabinet under the bathroom sink, and running along the inside bathroom wall under the cabinet. Dealer could not find source of leak. Any help would be appreciated.Attachment 211891Attachment 211892Attachment 211893
Another pic.Click image for larger version
Old 08-09-2019, 07:51 AM   #3
I had a leaky black tank flush valve that leaked when I flushed the blank tank and it took a span of time to put two and two together.
Also, maybe it leaks depending on the attitude of the trailer (slant) when it rains. Might have been slanted away from leak at dealer.
2019 Rockwood MiniLite 2511s
2018 F150 2.7l EB
timetogo8 is offline   Reply With Quote
Old 08-09-2019, 08:14 AM   #4
Never saw a leak while flushing black tank.
I think you might be right if trailer leaning to that side, you may never see or notice the leak.
I was wondering if rain could get through black tank connection.
Old 08-09-2019, 08:53 AM   #5
When I run water on the outside connections of the black flush line, city water, and antifreeze connection water comes through all the connections into the inside wall of the trailer.
Old 08-09-2019, 09:16 AM   #6
This cannot be right. The water goes through the wall on all three connections easily. Small stream of water. Identical type of connection.Click image for larger version
ID:	211912Click image for larger version
ID:	211913Click image for larger version
Old 08-09-2019, 02:04 PM   #7
CGK
Camping with Labs
Can't be sure from the pictures, but it looks as if your anti-siphon valve may be in your vanity, along with the supply pipes. If those two hoses go to/from the anti-siphon valve, then there is a chance the leak could originate in that valve. Anti-siphon valves are notorious for failing, and I can tell you from sad experience that when they fail completely, there can be a ton of water shooting out from the valve (in theory, less water would leak from a partial failure or loose hose)......but that only happens around the time the black water wash-out feature is utilized. So if the rain coincided with times you used your blackwater wash-out, you may want to check that valve - but if not, you can forget the anti-siphon valve and may want to check the plumbing connections under the sink. Check supply lines and drain connections. If you didn't use any water at all around the time of the leak, then it sounds as if you are truly looking for a "rain leak." Visually inspect the roof and all of the caulking to ensure everything is as it should be. And if everything is as it should be, I have no idea where you would look next and apologize for not being able to offer any help. Good luck!
Chris, Paula, & camping Labs, Shasta & Cammie
2005 Yukon XL 2500 with 8.1 Engine, Allison Transmission, and 3.73 Axle Ratio
2019 Rockwood Signature 8335BSS
CGK is offline   Reply With Quote
Old 08-09-2019, 03:55 PM   #8
drelec's Avatar
Pressure Test
I googled pressure test RV and found this;
This Simple Leak Test Will Find Small Undetected Water Leaks
Prime Time Manf. Crusader 270RET 2012
Ford F150 5.4L B&W Companion Hitch
updated to Andersen Aluminum Ultimate Hitch 2017
drelec is offline   Reply With Quote
Old 08-09-2019, 06:58 PM   #9
Go up to roof and look for any hole, tear or separation in the rubber roof within the half of the unit that covers the bath area. Water will get in and follow the slope of the roof, down the wall structure and onto the floor.
bzac1954 is offline   Reply With Quote
Old 08-09-2019, 07:17 PM   #10
Flybob's Avatar
This cannot be right. The water goes through the wall on all three connections easily. Small stream of water. Identical type of connection.Attachment 211912Attachment 211913Attachment 211914
If you are saying water running down the side of the trailer is going in at the three water connections. you might want to loosen them and seal between the flange and the side wall. There should be a seal or gasket there.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-09-2019, 07:57 PM   #11
Please clarify
"When I run water on the outside connections"
Does the above statement mean:
  1. When I connect a hose to any of the connectors and run water through it
  2. When I spray water on any of the connectors from a hose and flood the area around it
If it's 2, then it seems that the manufacturer failed to put butyl tape behind the flanges of each connector. You should easily be able to demonstrate this to the dealer for a warranty fix.
Larry
Larry-NC is online now   Reply With Quote
Old 08-09-2019, 10:05 PM   #12
No, not that. What I am saying is if there is ANY tye of tear or hole in the roof, water will get under it and travel down (under the rubber roof) to the wall and then travel within the wall and come out where the side meets the floor.
