Old 09-21-2016, 10:17 PM   #1
Rear Electric Stabilizers
I have a 2010 Rockwood Signature Ultra Lite 5th Wheel. The rear stabilizer motor runs when the switch is depressed but the jacks will not raise or lower. I can manually lower or raise the jacks with the hand crank. My question is, is there a shear pin in the motor that can be replaced and if so how do I do it, or will I have to buy a new motor. Any help would be greatly appreciate.
Tazman1966 is offline   Reply With Quote
Old 09-22-2016, 10:32 AM   #2
fonzie's Avatar
Here is manual for Lieppert electric stabilizer.....yes there is a shear pin in motor coupler
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 09-22-2016, 10:45 AM   #3
When you use the Crank it is Driving the Shaft direct! The motor has a Gear box with Plastic gears,they Might/Could be bad! Youroo!!
youroo is online now   Reply With Quote
Old 09-22-2016, 10:51 AM   #4
That is what happened to mine. The plastic nut which runs on the screw stripped. I can still work the stab jack using the hand crank.
Marty
2016 Rockwood 2703WS Sapphire
2011 F150 Ecoboost SCAB/3.55
Martsing is offline   Reply With Quote
Old 09-22-2016, 07:31 PM   #5
Thanks everyone for the replies now I have to check to make sure the coupler shear pin is broken or not. Hopefully I will not have to replace the motor.
Old 09-22-2016, 08:00 PM   #6
Left Coast
4 screws and the motor comes off......the gears in all 3 of mine are metal....if you need a motor, E Bay is the place to shop
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 09-23-2016, 11:45 AM   #7
Thanks Bob will be taking the motor off this weekend and checking it out.
Old 09-23-2016, 11:51 AM   #8
Left Coast
The pin that's being talked about is in the stabilizer, not the motor......motor shaft has a slot that slides over the pin....
electric, stabilizers
