Old 10-14-2015, 08:17 AM   #1
Rear Receiver Hitch for Rockwood Mini Lite 2109S
I have a mobility scooter that weighs 275 lb. I would like to attach a hitch cargo carrier with ramp to the rear of my 2015 Mini Lite 2109S to carry my scooter. I know that attaching anything that heavy to the 4" bumper would be a mistake.
Has anyone attached a receiver hitch to the rear frame of their Rockwood Mini Lite and if so, how? .... and how has it worked out? Any towing problems, etc ?
Did you have it welded to the frame or use one of the universal/adjustable hitches that bolt to the frame (DIY) - if so, which one did you use.
Any information, including links, pictures, lessons learned would be greatly appreciated.
Wife and I love our Mini Lite 2109S. It is perfect size for the two of use and has all the features of the bigger rigs. Headed to the smokies in two weeks to see Fall colors.
GaTTCamper is offline   Reply With Quote
Old 10-14-2015, 09:19 AM   #2
We had the Flagstaff twin to your 2109S and loved it. But I wouldn't advise adding 275 lb to the aft end, as it would be likely to reduce your tongue weight and introduce excessive sway.
"But, oh that magic feeling, nowhere to go." -- The Beatles
2015 Flagstaff 8528RKWS fiver
2013 Ram 2500 CTD Laramie CC SB 4WD Auto
cbconway is offline   Reply With Quote
Old 10-14-2015, 09:38 AM   #3
I have the flagstaff version of the same camper. Its a great camper and we love ours, but the bumper is not able to handle that type of weight.
If you weld a receiver to the frame, you will void your warranty.
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 10-14-2015, 09:43 AM   #4
TURBS's Avatar
Frame isn't designed for that kind of weight either.
Professional welder or not.
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
Old 10-14-2015, 09:46 AM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
Any addition of bike rack voids the warranty. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 10-14-2015, 12:17 PM   #6
Canadian Member
itat's Avatar
Will the scooter fit in the back of your Tacoma? Maybe you can move whatever you carry in the truck bed to inside the camper?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 10-14-2015, 01:23 PM   #7
Commercial Member
Agreed on several of the comments above... What voids the warranty is what is called "Altercation to the frame", and this comes from Lippert, not Rockwood/FR. The extra weight on that short of unit, will cause a drastic change in the hitch weight, which will cause the Rockwood to sway all over at speeds increase. A thought on what to do is explore a hitch extension from your tow vehicle, such as done in pick up campers. There are kits available to extend the receiver hitch back with safety chains back to the side of the tow vehicle hitch for stability... Then possible to have something produced to hold your scooter.... (if only I could draw a picture in message)
2-B-REIL is offline   Reply With Quote
Old 10-14-2015, 02:24 PM   #8
One of the main concerns with attaching anything to the back bumper is the constant whipping motion of up, down and side ways that happens when running on rough or rolly-pollie roads. Anything attached to the bumper, or extended beyond the rear end will be sitting on the pavement if not firmly attached to the frame!
gfarmcafe is offline   Reply With Quote
Old 10-14-2015, 02:27 PM   #9
TURBS's Avatar
The frame on a "light" trailer is well giving it to much credit.
Lite and ultra lite frames are tin grade metal and welded together to resemble an I beam.
The frame is no heavier than the bumper and should never be used to carry a load outside of the camper itself.
Period.
TURBS
2015 columbus 320RS
Old 10-14-2015, 03:07 PM   #10
Rvdixie's Avatar
Adding that much weight aft of the rear axle will cause you tremendous towing problems as has been mentioned above. You will develop an uncontrollable sway and it could be very dangerous. I would concentrate on finding a way to put that puppy in the truck.
Richard & Rosalba Charron
Zephyrhills, FL
2015 Ford F150 Eco Boost
2016 Coachmen Chaparral Lite 29MKS
Rvdixie is offline   Reply With Quote
210, 2109s, hitch, rockwood
