Old 07-03-2012, 08:50 AM   #1
Rear storage door and running light issue
Anyone have a Rockwood 2608ws before 2013. Did the rear storage compartment push against the running light? can't even latch the door, the light is so much in the way.
Will post some pictures..
2011 Ford F150 XTR Supercab 4X4 Echoboost 3.5L
145`Wheelbase, 3.73 ratio LSA & 7700lb GVWR
Max Trailer tow & P275/65R18 OWL ALL-Terrain
2013 Rockwood 2608WS
pasquale is offline   Reply With Quote
Old 07-03-2012, 08:58 AM   #2
Here are the pictures, any recommendations I am going to the dealer today to ask the same question.
Old 07-03-2012, 09:25 AM   #3
TURBS's Avatar
Well that's just silly!
I amagine they'll just add another latch.
They used a t latch on my front cubbyhole door on my 5er as to not allow door to open to far and interfere with slide out opening and shutting.
They installed in the middle of the door down low Eucharist makes the door not open as far.
Old 07-03-2012, 11:23 AM   #4
I 'd bet the cutout jig was missaligned when the light was installed. Possible to move lite up enough to clear w /o exposing the wire hole?
mararra is offline   Reply With Quote
Old 07-03-2012, 01:14 PM   #5
I dislike those latches so much that I put gas struts on all the storage doors so I don't have to use them. You might have to make a spacer for the latch to get the door out far enough to clear the light.
Somebody goofed big time!
Sorry, I'm not laughing at your problem, but someone should have caught that at final inspection or at the dealer and corrected it.
Old 07-03-2012, 03:04 PM   #6
Sounds like a cool idea. What brand of struts did you get? Assume they are like ones that you could use for a car trunk etc....
thanks.
merlin66043 is offline   Reply With Quote
Old 07-03-2012, 03:18 PM   #7
thanks.
Suspa C16-09786 30#, 2 per door.
Forest River Forums - dunnnc's Album: Gas Struts on storage doors
Old 07-05-2012, 11:23 AM   #8
Wow that is a great idea...
What did you use to reinforce the door so that you could screw it on?
Pasquale
Old 07-05-2012, 11:38 AM   #9
Pasquale
Pop riveted 1/8" thick alum plates to the doors.
