Old 05-02-2016, 11:11 AM   #51
KnP
As I said, not in a hurry... Just testing the waters. Cruised most of the time at about 65 MPH. Sometimes you poke a bit higher when passing. Heck, was another guy hauling a TT (seems to be a Toy Hauler) that was pretty much doing around 80 MPH. Tried to get catch the draft but he was going way too fast; no reason for going that fast and way too risky.
Another gadget that worked out pretty neat was the CB Radio. We encountered a "Stau" (autobahn talk for traffic jam) and as usual, no clue on what is going on. The wife got on the horn on CH 19 and asked to any southbound Truckers what is about. Turned out to be a wreck and also told us on what line to be on to avoid getting stuck.
2016 Rockwood 2306
2016 Chevy Colorado Z82 / 2009 Pontiac G8 GT
KnP is offline   Reply With Quote
Old 05-02-2016, 01:38 PM   #52
Charles Firth's Avatar
I try to stay at 60 to 65 mph comfortable speed for me. I sometimes tend to forget the Jammer is even back there. That seems to work for me. Like someone said enjoy the journey.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
Old 05-07-2016, 06:48 PM   #53
wbdavey's Avatar
KnP - in your original post you stated that the WD hitch was properly adjusted. I found with my rig that adjustment by the book was close, but adjustment by truck scales made all the difference in the world. My "book" called for measuring the gap between the front tire and fender, and I was very close. Going across the truck scales my front axle was within 200 pounds of the truck alone number. I went up one more bolt hole on my L brackets and the weight was within 60 pounds of the truck alone number and the handling was dramatically better. You may be close, but it's worth $15 to get it weighed and know your perfect.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 05-07-2016, 07:08 PM   #54
Retired JSO's Avatar
Most older tires are rated for 65 MPH. Our new W&P has tires rated for 75 MPH. I always try to keep my speed where the trucks seems to have a sweet spot. Between 62-65 on a smooth interstate.
Retired JSO is offline   Reply With Quote
Old 05-07-2016, 07:37 PM   #55
cphubert's Avatar
WOW I must be getting old I don't drive at 80 without the trailer- never over 65 with it in tow. I hope you never have to stop fast or lose a tire.
cphubert is offline   Reply With Quote
Old 05-07-2016, 08:12 PM   #56
Orion's Avatar
Yep we are little older and more conscious of our immortality 🤕
Sent from my iPad 18 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is offline   Reply With Quote
Old 05-07-2016, 08:34 PM   #57
Towing, I seldom get over 65 except when passing, but driving TOWTA's old junker, it is hard to not help the cruise control until the RH governor kicks in with a verbal warning when exceeding 80 mph.
Old 05-07-2016, 09:18 PM   #58
KnP
Found out that most of the problem is the road itself. Going down on a nice paved road is straight as an arrow. Funny thing is... passing 18 wheelers is not an issue. The ones that gives me most of the instability are the Dually Pick Ups; those for sure push a lot of air. Some roads are worn to the point the TT wheels seems to "track" and give some sway.
Sat myself at a good spot and set to 65 MPH, smooth as heck. Few times pushed to 70 MPH for some passing. Very smooth and predictable.
2016 Rockwood 2306
Old 05-10-2016, 09:47 PM   #59
Limey's Avatar
Always remember your trailer usually weighs more than the vehicle towing it, & when you loose control & your TT takes over, this is what happens..
Name:	TT wreck.jpg
Limey is offline   Reply With Quote
Old 05-11-2016, 08:27 AM   #60
BigDaddy1967's Avatar
Originally Posted by dragon-roo View Post
The other thing to consider is that the effect of the wind drag as you increase speed, can REALLY drop your MPG.
I'm so cheap that I squeak, so I tend to drive no more than 60 MPH when pulling. Besides... I'm camping, so I would rather relax and not be in a rush, like I am every other day of the year.
YMMV
X2, more expensive to go faster. I learned quickly, on my virgin pull that you should not be rushing when it comes to towing. Fortunately, my learning was not expensive or nothing broke, just a nice wake-up call👍
2014 Ford F250 Super Duty, 6.7L Diesel, Ultimate Lariet package
2016 Forest River, Heritage Glen 272RL
BigDaddy1967 is offline   Reply With Quote
