Old 12-11-2015, 01:52 PM   #1
fayliss's Avatar
Recommendations for TV Bracket in Bedroom
I just purchased a 2016 Rockwood 8286ws Ultra lite and I need to mount a TV bracket in the bedroom. Does anyone have a recommendation for what type and brand to use. Probably will put up a 15-17" TV.
Fayliss
Hilton, NY
2016 Rockwood Ultra Lite 8286ws Fifth Wheel
2011 Silverado 2500 HD, Garmin RV760MT
6.6 Duramax Diesel, Allison Transmission
Travel Companions - Rocky and Emmy
fayliss is offline   Reply With Quote
Old 12-11-2015, 01:55 PM   #2
The TV location in our bedroom only allowed for a 12 inch TV. And it was at a horrible angle. So I removed one cupboard door and made my own mount out of some aluminum angle and flat bar. That way I can get a 22 inch screen.
donniedu is offline   Reply With Quote
Old 12-11-2015, 02:50 PM   #3
onetonford's Avatar
Name:   level mount.jpg
Here is what I uHere is what I used bought from Home depot. It is removable so I can set it on the bed for travel I don't trust the wall even thou I found the stud and plywood mount in the wall. I think the brand was called level mount. I have a 22 inch vizio twelve volt tv mounted ot it.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 12-14-2015, 07:36 PM   #4
Bought this at Best Buy. All I needed was the tilt up and down for my tv location. It is removable too.Click image for larger version
Name:	ImageUploadedByForest River Forums1450139788.182576.jpg
2015 Flagstaff 29FBSS
Camping: 2016 - 22 days so far and lots more scheduled; 2015 - 40 Days, 2014 - 20 days
Aggie_90 is offline   Reply With Quote
Old 12-14-2015, 09:56 PM   #5
camping baba's Avatar
We have a 8280 and bought a wall mount at our dealer that mounts to the right of the bathroom door . It has a lock for travel and is able to be pulled out and turn . We have a 22" TV mounted there .
2013 Silverado extended cab 4x4 1500 Series
camping baba is offline   Reply With Quote
Old 12-15-2015, 12:00 AM   #6
Blog: RVroadtripper.com
hbillsmith's Avatar
You can find many for that size TV. Check newegg.com and Amazon. Don't expect to pay more than $15 to $20. Any VESA 100 std bracket should work.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 12-15-2015, 02:56 PM   #7
We may have overkill, but it is strong, locks in position, articulates and tilts. The TV is also easy to remove in a couple of minutes for winter storage. We have a 19" TV mounted and the mount will hold up to a 32". It is vesa complaint. We ran all of the wiring inside the wall.
Master Mounts 403L TV Wall Mount Locking Cantilever Silver Mount TVs in RVs | eBay
PenJoe is offline   Reply With Quote
Old 12-15-2015, 04:01 PM   #8
hbillsmith's Avatar
Detachable Bedroom TV mount for RV
This is the one I used in my previous Dutchmen Kodiac. I liked it because it has a heavy duty latch that made it easy to remove and put back. Price was right also.
Old 12-20-2015, 09:35 PM   #9
I was looking at mounting a TV in the front bedroom of our 8327SS. What do you use for screws/lag screws to go into the wall? It says there is backer board to mount to but the wall is not very thick.
2008 Duramax K2500 Suburban
Allison 6SP - DSP5 Tuned
2014 Rockwood 8327SS
2012 Grey Wolf 28BH
2008 2500 Duramax Suburban
arich4387 is offline   Reply With Quote
Old 12-21-2015, 09:28 AM   #10
The Master Mounts 403L was mounted in the BR of a 2500TS. Wood screws of appropriate length hold it to the wall and it supports a 12 volt 19" TV very well. There are two concerns when doing this: fully mounting the mount to the backer board and not damaging any wires that are in the wall. Hopefully some of the info below is helpful in your application.
We have a 12 volt cigarette lighter/coax connection in our wall in proximity to the TV location. This was unscrewed from the wall. DW let me use her compact mirror to look up inside the wall to see the backer board and to check the wires routed inside the wall.
I then took an aluminum yard stick, with a finger inside the wall holding it to the wall panel, pushed it up inside the wall until it bumped the backer board. A tape measure would work as-well. With that measurement, I measured up the outside of the wall and placed a piece of masking tape to mark the bottom of the backer board. Then measuring down from the ceiling, I moved over to where the TV mount would be placed and marked it with masking tape.
No wires interfered. The TV mount was attached to the wall. The length of the screw is the approx. 1/8" panel thickness plus 3/4" for the backer plus the thickness of the mount, probably about 1 1/4". The studding is about 1.5", so you do not want to penetrate the other side.
A household single coax hole wall plate (painted to match the mount) was used to mark the cable and 12V wire hole next to the mount. A bit larger hole was then drilled into the wall at the mark. The wires were fed through the wall and a coat hanger wire was used to catch the wires and bring them to the connection plate previously removed. The 12V wires were spliced in behind the cigarette lighter plug and a female to female coax connector attached the antenna connection. The wires to the TV set were attached to follow the articulating arm.
This is a very clean looking install. By disconnecting the 12V plug, the coax cable and removing 2 tilt knobs, the TV can be removed for winter storage. This is less than a 5 minute process.
bed, roo
