Old 04-15-2015, 09:11 PM   #11
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
Originally Posted by OldCoot View Post
I took the handle off mine and made a handle only about 12" long from the hitch head with an 8" T on the end.
OC...Is there anything you haven't modified?
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnegbago Adventurer 38Q....26K Chassis
...traded in 2015 Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is offline   Reply With Quote
Old 04-15-2015, 09:30 PM   #12
Didn't modify the handle, I just took it off as it wouldn't fit under the "slightly altered" tonneau cover.
Old 04-16-2015, 05:25 AM   #13
Witch Doctor's Avatar
Originally Posted by darhike View Post
I just bought a Ram 1500 2015 with Ram box and now worried that the hitch will not work in the 4' wide bed. My new 5th wheel will have the Reese Evolution pin. Will I be able to work the lever on the hitch since the bed is only 4' wide?
Don Flagstaff 5th wheel 28rkws
Not all hitches are the same size (Wide.) Look for the smallest one with the capacity that can carry the unit. Such as a 16K. Also check and see how hard it would be cut the pull handle out. A 4' wide bed would be tight. Look at a husky 16K that might work. I just looked at mine I could cut 4"or 5" off the pull handle. It only connected to the mech. by a bolt so It could be cut, From the center of the jaw with the handle fully pulled out is 23". It will also depend on the frame of the truck for mounting the rails. Hope that helps you out look at etrailers and also call them, they probably can tell you more. If you make up a tee to replace the handle it would fit easily.
Coachmen M/H
Concord
2018 / 300 DSC
