Old 07-01-2013, 11:34 AM   #1
Reese Revolution pin box, stiff??
Well I finally 'activated' the Reese Revolution on our 8280WS and I must say, so far, I really like it. It's allowed us to get into (and out of) and lot of tight places. I do, however, have a couple of questions.
The one thing I don't like about it is that I have to get the truck lined up really well in order to hook up. If I don't the thing will just plain not couple so I have to try again. One thing I thought I could do to help this would be to rotate the pin box to align it with the hitch before I backed up. The problem with this idea is that the thing is so darn stiff I can't move it! When the truck is connected it can move it with no problem, but then I guess it has a bit more power than I...
So the question is... is this 'stiffness' normal or is there something wrong? If it is normal, can I expect it to get looser over time?
Thanks in advance,
Gord
cachencouple is offline   Reply With Quote
Old 07-01-2013, 12:05 PM   #2
If it wasn't stiff, that would mean there is slop in the pinbox, and that wouldn't be a good thing.
bakken is offline   Reply With Quote
Old 07-01-2013, 12:46 PM   #3
Warrior's Avatar
I have the same difficulties connecting, if the truck and rig are not lined up...grrrr. As far as stiffness, more often than not I can't physically move the pin box, occasionally I am able to move it though. I contacted Cequent Towing Products the distributor regarding this issue and they assured me this was normal. As far as eventually getting looser over time...I have close to 5,000 miles on mine and no sign of loosening,
Wayne & June Bowers Camp Mutts Bo & Baby
2011 F250 Lariat 4X4 SCSB 6.7 Power Stroke
50 Gallon Titan Fuel Tank
2011 Flagstaff 8528RLWS 5th Wheel
Reese Sidewinder Hitch 2002 Road Star Warrior
SouthWest Florida FROG
Warrior is offline   Reply With Quote
Old 07-01-2013, 01:13 PM   #4
Fulltime family RVer
I was about to say what Wayne or June (Warrior) said - someone posted a thread recently about this and was assured by the manufacturer it is normal to not be able to turn the pin box by hand.
ependydad is online now   Reply With Quote
Old 07-01-2013, 03:23 PM   #5
Last winter I was at the RV show in Tampa and they had one on display. Yes you guessed it. You could move it with your finger.
acacia580 is offline   Reply With Quote
Old 07-01-2013, 06:38 PM   #6
Paul & Sheri
pwb01's Avatar
I also find it extremely difficult to connect and disconnect. There's no room for error at all . Also the other thread said that if you can move the pinbox you'll have to have it corrected. I disconnected yesterday and got that alignment bar so locked up I thought I'd never pull away because I was just a few degrees from straight. I know the next hookup will be a challenge but less so I I could only straighten the pin box. My neighbor and I both pushed and the landing gear slid. Wouldn't have thought it.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 07-01-2013, 08:04 PM   #7
Jjsav's Avatar
I found that I can move it right after I disconnect (does not move easy). So as soon as I disconnect, if I have to, I straighten out the pin box so it is a straight run hooking up. It makes life easier hooking up.
If I wait I can no longer move it.
2018 Jayco Eagle 355MBQS, Andersen Ultimate Hitch
2013 Rockwood 8281SS 5W, Reese Revolution (sold)
2016 GMC 2500 Denali HD 6.6 Diesel
2016 Victory Cross Country Tour
2012 Toyota Tundra Crew Max (sold)
Jjsav is offline   Reply With Quote
Old 07-01-2013, 08:09 PM   #8
MtnGuy's Avatar
Could you make some type of cheater bar that would fit over the pin and the guide so you could move those puppies easier ??
Old 07-01-2013, 08:18 PM   #9
Rugged Brown's Avatar
I've been using the RR for 3 years and have never experienced any difficulty hooking up. It is rarely lined up perfectly but hooks up just fine. I cannot moved the pin by hand.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
Trying to resist the urge to buy another camper
Rugged Brown is offline   Reply With Quote
Old 07-01-2013, 08:23 PM   #10
Senior Moment
rockport's Avatar
I can move mine from side to side quite easily , so I am going to call tech support tommorrow in case mine needs to be tightened down.
rockport is offline   Reply With Quote
