Old 03-17-2015, 08:49 PM   #11
Originally Posted by fraz55 View Post
It's a NorCold N611. Am more worried now-- it's been on for awhile and only feel coolness in the freezer, nothing in the lower part. Is that normal?
Putting dual fans inside the frig and dual fans outside at the bottom of the tubing and above the burner will decrease the cool down time and increase the overall cooling capacity of the unit. When I turn the frig on, I also turn all 4 fans on. I never run the frig without the fans.
Old 03-18-2015, 08:50 AM   #12
DaveSchwartz's Avatar
Although you've got it cooling on gas now, I haven't heard that you solved your AC problem.
You should check (test and reset) all your GFCI's. The outlet that the fridge AC cord is plugged into (behind the inlet vent panel on the side) is GFCI protected... it may be its own GFCI but more likely to be a downstream-protected outlet off either a kitchen or bathroom GFCI (out previous TT had only one, our new FW has an additional one in the kitchen).
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 03-18-2015, 08:56 AM   #13
fonzie's Avatar
Go to this new thread....
Can an amateur change NorCold 5-amp fuse?
Fonzie
Old 03-18-2015, 09:13 AM   #14
Fraz, what you need to know is that refrigerators are really just freezers, that bleed, or fan assist cold air into the "fridge" portion. Rv dual fuel refrigerators work slighly different, but the principle is the same. The freezer needs to be at spec temperature, before the fridge section can attain its designed temps.
Old 03-18-2015, 11:14 AM   #15
SYE
SYE's Avatar
Make sure your Battery switch is on
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 03-18-2015, 11:16 AM   #16
Won't work on gas without 12v.
Old 03-18-2015, 12:52 PM   #17
Stormrider151's Avatar
If you want it to cool down faster freeze some bottles of water and put them in the fridge. We turn ours on 4 days before a trip with the bottled water. That side of the trailer is in direct sun most of the day and slows it progress.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-18-2015, 01:09 PM   #18
ColoradoRick's Avatar
Yes, they take quite a few hours to get cold...we always park the trailer outside our house the night before heading out in order to both load it up and get the fridge working. (And leave it on gas while driving to keep cold.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
gas, light
