Old 03-28-2014, 02:09 AM   #1
TopTiger's Avatar
Removing Drawers
OK, I give up! Can someone please tell me the secret to removing a drawer in a 2014 Signature Ultra Lite Model 8286 FW from its slide hinges? I need to get under galley sink to fix leak in faucet but need to get drawers out first to obtain access. Been messing with the drawer for almost an hour and can't figure it out.
IT'S GREAT TO BE ALIVE!
Bob & Marie
Rockwood 8286WS "Bunker"
Ford F-250XLT 2WD 6.4LD
TopTiger is offline   Reply With Quote
Old 03-28-2014, 08:30 AM   #2
jeepman71's Avatar
If it is a standard full extension slide the drawer out about half way, there will be a little black "finger" in the rail on each side. One side you need to push down, the other pull up. When you have them in the correct position the lock will release and you can slide the drawer out. Sometimes it takes some trial and error, if you have any tension on the locks from pulling the drawer while releasing the lock the lock will not release.
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline   Reply With Quote
