03-11-2016, 07:52 AM
Removing Drawers (no, not like that...)
I have asked before and have been told that the kitchen drawer in my 2306 can be removed. I have tried several times and have not been successful. I see little black 'buttons' on each side of the slides, and I've tried pressing them, but still no dice...
We had a bowl go over the back of the drawer and down to the bottom of the cabinet and had to rig up a clothes hanger to fish it out because the drawer wouldn't come out.
Any additional instruction would be great!
2015 Rockwood 2306
2015 Tundra CrewMax
03-11-2016, 09:14 AM
On my WJ, when you have the drawer all the way out to it's stop, there are little black tabs on each side, if you look carefully you will see they are the same part just mounted upside down compared to the other side. Push one tab up and the other goes down and that releases it.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
03-11-2016, 09:21 AM
Yes! Youroo!!
04-28-2016, 07:34 AM
Maybe I'm a complete idiot, but I have tried this twice now, and still no luck... Grrrr!
Does anyone have pictures or even a short video?
2015 Rockwood 2306
2015 Tundra CrewMax
04-28-2016, 07:44 AM
As already stated the little black tabs or button is the key here. The first time that the buttons are pushed it is a little hard to press them in far enough to get them to release. So either push the levers as stated you should be able to see the black button or tab move toward the center of the drawer or push the button until the same. Then pull out on the drawer while you are pushing the tabs and it will come all the way off the slide.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
04-28-2016, 07:48 AM
2015 Rockwood 2306
2015 Tundra CrewMax
Here you go...
04-28-2016, 08:15 AM
I have to ,I put this "Removal" right along side "Windshield Wipers" replacement! I threw my hands up and go back to the auto parts store where I bought them and let the counter person change them! You know the "Auto Parts with Signs, Wiper Blades Installed FREE" Youroo!!
04-28-2016, 08:44 AM
I spent a good 30 minutes messing with mine before I figured it out. I could get one side to release but not the other. Finally figured out that the little black tabs were opposite on each side. One I pushed up on, and the other down. Then the drawer would come out.
On a side note I was taking mine out to try and figure why it won't catch and stay closed like the others. Never did figure that out.
Sean
'16 28DBUD
'16 2500HD Dmax
04-29-2016, 06:20 AM
Thanks to everyone here, I figured out the error of my ways... I was pressing the wrong buttons.
These were the buttons I was pressing:
I finally figured out its actually these buttons:
And here's what I was trying to access. The large drawer isn't supported very well on the left side, which allows it to "shift" to one side and bind when you open it. I saw another member on here who screwed and glued a support block to the left upright, so I did the same. It help immensely.
2015 Rockwood 2306
2015 Tundra CrewMax
04-29-2016, 06:46 AM
53 good job,the side rails have been Shakey installed for a Long time in RV's! They used to have Little Plastic brackets that slid into the end of the rail and were held into Luan by 1 little screw! Now that was a Real Joke install! Youroo!!
04-29-2016, 07:18 AM
Or a poorly, half installed staple!
04-29-2016, 07:33 AM
I forgot about the Staples There were holes in the L brackets for 3-4 screws but they would Only put in 1 and that one was always on the bottom and would allow the bracket to Turn & Break! PS they have hired the "Staple Guy" to now install the Carpet in Slides at F/R and told him "Have at it, pretend your Dad owns a "Staple Supply Store"! Youroo!!
