Replace a Reese Revolution 10K with Trail Air
I have a 2016 Rockwood 8244WS fifth wheel that has a Reese Revolution 10K pin box, VHD-10K22SW. I don't need the sidewinder feature, and I have removed the wedge, and installed the 2 lockout bolts.
I would like to replace the Reese Revolution with a Trail Air LC158778, rated at 21K. This pin box measures 12 inches wide. The problem is the width of the trailer frame (LCI 3073621) only accepts 10.5 inch wide pin boxes. I contacted Lippert, an they told me only the Reese Revolutions will work with this frame.
Is it possible to have a machine shop build an adapter plate to install with the Trail Air pin box? Matt
