Old 05-25-2015, 10:17 AM   #1
markb5900's Avatar
Replace Radio Antenna
Hi
We are loving our new 8289WS so far but the radio reception is terrible.
Think I could get better reception with tin foil, so thinking I will replace the current antenna. (see pic).
Started to take it off and the bottom is TIGHT, assume that is where the cable is hooking up to it, but it is so tight, I can't get the antenna even 1/8" away from the wall. Screw is all the way out, so has to be the coax.
Wondered if anyone else had removed and changed there's?
My only concern with pulling it off is I will never get it back on again if the coax is that short, no way to hold it to push it into new antenna.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 05-25-2015, 11:51 AM   #2
Stormrider151's Avatar
I replaced a wall plate for my TV and ran into the same thing. I thought the coax was short. What it was , was the coax was coming up from the bottom. I had to tilt the top out and lift up so the coax would clear. It was tight but it came out and there was about a foot and half of coax to work with. maybe that would work.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-25-2015, 12:20 PM   #3
Owner/Operator
RodeoGeorge's Avatar
If it is primarily the FM reception that you want to improve, check out Posts #17 and #19 of this thread.
8289WS - Modifications
This will not improve the AM reception. Just the FM and Weather.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 05-25-2015, 02:21 PM   #4
Originally Posted by markb5900 View Post
Hi
Would like to do the same. Please keep us updated!
MartyQ is offline   Reply With Quote
Old 05-25-2015, 05:36 PM   #5
markb5900's Avatar
Went and bought just a normal car antenna replacement. Plugged it in and it is better, not what it should be, but is better.
A little red neck engineering and have it stuck in the cabinet behind the radio unit.
Will probably end up doing the tv antenna mod to get it really good. But at least now, we can pick up the stations that are less than 10 miles away.
Mark B
2017 GMC 3/4 Ton TV
Old 07-16-2015, 09:14 AM   #6
RangeMaggotBob's Avatar
Hi
I'm having the same problem- but looking at your picture, it looks like the antenna pulls out like the old fashioned car ones used to do. Maybe I need to pull mine out?
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 07-16-2015, 05:41 PM   #7
canterburyshoe's Avatar
I had the same problem and one of these forums suggested to hook up the radio to tv antennae on the roof using this adapter Motorola to F Connector 36'' Cable | 10TV110 | Distributed By MCM. I installed it this past weekend and I went from no reception at all to 10 stations up in Pittsburg NH. Best $10 I've spent on the camper.
2017 F350 6.7 PS extra cab long bed
Curt G25 hitch
Days camping 2016 - 26
canterburyshoe is offline   Reply With Quote
Old 08-21-2015, 05:27 PM   #8
An update. Had the techs at Goshen replace the side mounted radio antenna with the same. FM and weather reception improved slightly but was poor. AM reception was non existent. The techs indicated the only viable solution is to connect the radio to the TV antenna (or abandon the side mounted and put one on the roof). They even brought the adapter cable and another splitter!! Ended up disconnecting the TV cable that leads to the unused front compartment connecting the radio to the installed splitter. (I had the adapter cable). No need for another splitter. Excellent FM and weather.
They indeed try to please!!
Old 08-22-2015, 07:09 AM   #9
tdidad's Avatar
Mine is the same, we have an 8289WS and no radio reception anywhere, anytime. It's gone back to the selling dealer with a list of things to fix and the radio was one of them.
Ď17 Rockwood Signature 8328BS
tdidad is offline   Reply With Quote
Old 08-22-2015, 07:28 AM   #10
PhoneDude 8289's Avatar
I did the Radio mod after reading what RodeoGeorge did and it brought in so many clear FM stations and the weather band. Never listen to AM anyway, so happy with such a simple mod.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
radio, antenna
