Old 04-10-2014, 09:40 PM   #1
Smile Replacement Microwave Oven
The .9 cu ft microwave in my Windjammer 3008W has failed and I can not find a replacement. Camping World has a Dometic 1.1 cu ft model that I think, worth some modification to Windjammer it will fit. Does anybody have a better Idea?
fastedie is offline   Reply With Quote
Old 04-10-2014, 09:48 PM   #2
Replaced mine with one from Wal-Mart and has been working just fine. As long as it will fit or can make it fit.
2004 Chevy Silverado 2500HD Crew Cab Duramax
2013 34TBOK-6 Palomino Saber Bunk House
Tucson,AZ
RONN is offline   Reply With Quote
Old 04-18-2014, 11:39 AM   #3
Alleged curmudgeon
Vern's Avatar
No insult intended, but the correct first question is whether you have double-checked to make sure a breaker has not popped? Second, have you pulled the appliance out to double-check and be sure it is plugged in (the outlet is inside the cabinet behind the unit)? Third, have you plugged something else into the receptacle to be sure the power is working?
Our microwave failed within a week of delivery and those were the first things the dealer had us do. As it turned out, the microwave was defective and was replaced under warranty (i.e., the factory sent the dealer a new microwave and they swapped it out). Therefore, I did not have to shop the replacement, so I can't help you there.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
Vern is offline   Reply With Quote
replacement
