Old 09-08-2016, 10:31 AM   #1
Replacement Stabilizer Jack
I shmucked up one of my stabilizer jacks on my new 2502KS TT last weekend. I won't go into details other than to warn others not to trust rubber wheel chocks to hold on a grass side-to-side slope. They'll slide on wet grass.
I can't get to my trailer for a few days and I need to order a new stabilizer jack. I don't know what size/model is necessary. Can anyone recommend which model/size/weight capacity to match the others before the Boss notices?
2014 Ford F150 EGOBoost
2016 Rockwood 2502ks
jlmanatee is offline   Reply With Quote
Old 09-09-2016, 03:06 AM   #2
Herk7769's Avatar
This is most likely what you are looking for.
https://store.lci1.com/ultra-lite-el...ite-switch-box
Only 4 bolts hold it on and its very easy to change.
Herk
You are not alone:
Name:	camper damage 038.jpg
HAM CALLSIGN - KC3FFW
Old 09-09-2016, 01:18 PM   #3
Thanks Herk,
Mine are manual scissor jacks and not the cool electric ones. But your response pointed me in the right direction (Lippert) and I was able to figure out what I needed there.
Old 09-09-2016, 02:50 PM   #4
Herk7769's Avatar
Awesome.
Old 09-12-2016, 03:13 PM   #5
I just had my first rookie mistake camping this weekend for the first time in my rockwood by bending my back electric stabilizer trying to put it down to far. Any places out here with decent prices on them and can I do it myself with a set of wrenches?
1Brownie is offline   Reply With Quote
Old 09-12-2016, 03:18 PM   #6
Herk7769's Avatar
I know we always say "do a search" before you ask; in this case, just scroll down
Old 09-12-2016, 03:23 PM   #7
1Brownie,
If your rear stabilizer looks anything like the one in Hrek's photo, the leg/arm can be removed, straightened, strengthened, and replaced without much hassle. The entire rear stab (replacement) is about $400. It can be repaired for way less.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-12-2016, 03:37 PM   #8
Where do you live? Are they as mangled as these? Bottom picture is just before they were re-installed as axle jack on Bob Caldwell's camper. They work just fine.
ID:	120029   Click image for larger version
ID:	120030   Click image for larger version
ID:	120031   Click image for larger version
ID:	120032   Click image for larger version
Name:	Modified Jacks extended.JPG
Old 09-12-2016, 03:39 PM   #9
yes in the photo but it just bent the u-channel arm. I don't see where I can buy that only, instead the entire system it looks like?
Old 09-12-2016, 03:44 PM   #10
I've not see replacement 'legs' just the side arms and the motor.
Remove and repair.
replacement
