Old 10-30-2018, 10:10 AM   #1
Replacing factory cd/radio
We are the original owners of a 2011 Mini Lite 2304. The unit has its original entertainment center that has the rubbery feeling radio/cd player they used back then.
Over time in the heat, this soft rubber like coating melts and becomes very sticky and messy. I tried cleaning the coating off and its better but when you do that the button labels disappear and it doesn’t look great.
Has anyone had to replace theirs and any suggestions for a replacement unit that works with the systems in the camper?
I love the new mini lites, they’re much improved over ours, but we’re not ready to get a new unit yet.
nhv71 is offline   Reply With Quote
Old 10-31-2018, 07:28 AM   #2
I can't help you with replacement, but I just picked up a 2011 Roo and was wondering why the face of the radio was so sticky. I'm also looking to replace mine as it doesn't work well at all. I've heard the iRV34 model fits and uses the same connections.
motor815 is offline   Reply With Quote
Old 10-31-2018, 10:02 AM   #3
Thanks for the info i’ll check that model out. The melting coating on ours also affected the buttons.
Old 10-31-2018, 11:33 AM   #4
try scrubbing the rubber with wd-40 sprayed on a rag or scrubby pad. it worked on the rubber coating of a hand held range finder I have.
Don & Kim
Willow Spring, NC
2012 Rockwood Ultra Lite 2604
2013 F-150 4x4 EB
vstrom is offline   Reply With Quote
Old 11-02-2018, 10:31 PM   #5
WNK2304's Avatar
T23040 c,
'18 Rockwood Mini Lite 2304
'13 GMC Sierra 1500 Ext Cab 4x4
WNK2304 is offline   Reply With Quote
factory, radio
