Old 07-05-2016, 01:33 PM   #11
I have a 2014 Flagstaff and had the same problem on the first trip. I took it back to the dealer and they disassembled the pin box and found welding slag was causing the noise and removed it. No noise since that repair.
jberdan is offline   Reply With Quote
Old 07-05-2016, 02:05 PM   #12
NMWildcat's Avatar
I'm on my second sidewinder. Never lubed the sidewinder 'bearings' themselves. Was told not to. But then I don't have any noises when it turns either. I do check the torque on the bolts on top of the shaft. They need tightening about once a year or so.
Have always been able to move both sidewinders by hand... but not easily.
I'd take it back to installer and have them give it the once over.
Scott and Liz - Southern NM
Old 07-05-2016, 02:12 PM   #13
CANADA FROG RALLY 2017
B and B's Avatar
Originally Posted by OldCoot View Post
Have you ever dropped the pin box completely down off the rear pivot and lubed it?
I'll go with the design engineers vs the tech. We know how good techs are.
Yes I did. Pictures were posted to prove it! As far as design engineers a field engineer like myself has always had to fix poorly engineered items made by others..
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 07-05-2016, 02:30 PM   #14
And having been a design engineer all but 10 yrs of my career, I have encountered MANY field techs/engineers that made "their" fixes which ultimately required replacing the unit entirely. Designers make mistakes, but very seldom are the designs corrected by a field tech. Just my own personal 40+ yrs of experience.
Old 07-05-2016, 02:34 PM   #15
reese revolution hitch
Have dealer drop large nut and lube per install instructions. fixes the problem.
cwinman is offline   Reply With Quote
Old 07-05-2016, 02:35 PM   #16
TandSH's Avatar
We also had the very noisy and impossible to turn by hand situation on our Flagstaff. Try as I might, I could never get any lube of any kind sufficiently into the turret to help at all. Finally bought a socket to fit the turret nut and lowered the pin box as far as possible without fully unscrewing the nut. This took two people and a LOT of effort. There was then sufficient clearance to clean the spalling paint/powder coating/whatever with a gasket scraper and thoroughly clean the contacting surfaces. A coat of grease then proper torque and pin the nut stopped all noise. The pin box can now be moved by hand with moderate effort and couples easier as well.
2016 Flagstaff 8528IKWS Diamond Pkg.
2016 F-250 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 07-05-2016, 03:05 PM   #17
I had the same issues as described with a hitch that wouldn't rotate. I disassembled it and found the axle with heavy heat treat scale. I had a lot of trouble disassembling the unit. With a lot of rotary wire brush action with a side grinder and re-assembly with white lube, it's not difficult to move it out of the way. Even so, if the unit sets for a long time, the hitch will screech but it is free to swivel when not loaded. It seemed strange to me that the factory would force this scaled pin down through a nylon bushing.
robertew is offline   Reply With Quote
Old 07-05-2016, 03:36 PM   #18
Revolution Pin
I have a new FW with the revolution pin and a Reese Titan hitch - I have a terrible time hooking and unhooking-- Just removed standard lube plate that came with the Titan and ordered the custom wedge- Any comments would be appreciated !
ksmith954 is offline   Reply With Quote
Old 07-05-2016, 08:07 PM   #19
pontiacdan45's Avatar
Send a message via Skype™ to pontiacdan45
Service Notice Reese revolution
First read the service notice from Reese. Also there is a great video from Cequent that shows the complete process of installing the wedge. What I found is that to lessen the problems with hitching or unhitching I had to have the wedge in the correct orientation to hitch and sometime when you can't get it to release the handle, backing into the pin box will solve the problem. Same with unhitching. Back into it to release the hitch handle. Once we mastered that we have no problems.
Pontiac Dan
2015 Rockwood Signature Ultra-Lite 8289 ws
2015 GMC Crew Cab 2500HD Gas:
pontiacdan45 is offline   Reply With Quote
Old 07-05-2016, 09:03 PM   #20
I have had two Rockwood fivers with the Sidewinder and both creaked and squeaked like crazy. I finally loosened the pin bolt and lowered the plate. I lubricated it with graphite and re-tightened the bolt. Noise abated for several months. I now lubricate once a year and that seems to reduce the noise.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
noise
