Old 05-14-2015, 04:55 PM   #1
Rock wood 8329SS-anyone rotated the electric tongue jack?
We can't open the truck tailgate because it hits the controls on the electric tongue jack. I just need another 1/2 inch clearance. The RV is in storage so I can't get the brand/model number. Has anyone successfully rotated the Jack/head? Was it very difficult? If not, does anyone know the brand/model and I can contact the manufacturer. There is no manual with the RV paperwork.
Thanks!
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
lakejumper is offline   Reply With Quote
Old 05-14-2015, 05:11 PM   #2
Moderators' Assistant
bikendan's Avatar
What brand is it?
I purposely bought an Ultra Fab jack so I could rotate the motor to clear my tailgate.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-14-2015, 05:12 PM   #3
Just three bolts & tongue jack is loose-not difficult at all.
Papa GLS is offline   Reply With Quote
Old 05-14-2015, 05:20 PM   #4
If you cant Rotate the Head or use the base bolt patern to clear,pull the Shank and Drill another 5/8 Hole for the desired clearance needed! Youroo!!
Old 05-14-2015, 05:24 PM   #5
If all other methods fail, you can take the jack to a welding shop and have the triangle flange cut off and rotated 180 degrees. Last resort tho'.
Old 05-14-2015, 09:41 PM   #6
Thanks for all of the ideas. I will go get the model number this weekend.
Old 05-16-2015, 10:49 AM   #7
AKA: 'tiredTeacher
awellis3's Avatar
I have the same problem. Can't rotate the mounting plate 120° 'cause the head is then into the propane tank. Can't rotate the jack head 90° 'cause the head isn't square and the holes won't line up.
Four solutions: Replace jack with a model that has a more compact head.
Re-weld the mounting plate, as mentioned by OC (except it would need to be a 90° rotation so the switches would be facing to the side of the rig, not aft.)
Buy a longer draw bar. This would move the ball further from the TV possibly creating more problems for the WDH.
I'm going with the fourth solution and am living with it.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-17-2015, 10:49 AM   #8
I went to storage yesterday and the model is a FIC 3500. It can't be rotated 180 degrees because the propane tanks are in the way. It can't be rotated 90 degrees because the bolt holes don't line up. They are configured in a triangle pattern and aren't equal distances apart. Drilling another hole won't work because it will compromise the strength of the coupler metal by placing two holes close to each other. My only option is to see if the head will rotate by itself or get a longer receiver drawbar as mentioned by Awellis.
Old 05-17-2015, 12:05 PM   #9
rbrumm's Avatar
Mine does the same thing. Thought about using the other hole on my receiver draw bar, but that changes the weight limits of my equalizer hitch.
2011 Ram 1500 Outdoorsman
2014 Rockwood 2909SS Emerald Package
rbrumm is offline   Reply With Quote
electric
