02-16-2012, 07:09 AM
"HAPPY CAMPER"
Rockwell / 8289 heating system
I would like to know how other trailer heating systems are installed? I purchased this unit and found that the return air is not pulling from the trailer cabin. FR is using my storage area as a return. Granted they put a 2 inch duct in that area but it is also drawing from a uninsulated area, and any odors from things that would be stored in that area. I turned the heater on and said why is this taking so long to heat. I should get at least a 35 degree temp. rise. That is to say that if my trailer temp is 65 on the inside the air being discharged from the registers should be around 100 degrees. If I'm pulling 40 degree air in from my storage area only, I would get a 75 temp max out of the heater. Let alone any odors. I have called FR and my dealer for a fix. I will keep you informed on what I think is a design flaw that should be resolved, let alone a safety issue. I just wondered if anyone else has this problem
02-16-2012, 11:06 AM
Moderator
Hello, and welcome. Now I hope you have a Rockwood trailer, because I can't find a Rockwell anywhere. Second, are you sure the the storage area is unheated? As to the storage area being uninsulated, it will have floor and wall insulation. As for measuring temps, you won't get a good temp for a while. Your furnace starts with the fan running, everything cold. Once the brain has the O.K. that the fan is running, the gas comes on and the ignition. Now it takes a while for the heat exchanger to get warm, since air is already moving across it. You won't get your greatest heat until near the end of the cycle.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
02-16-2012, 11:32 AM
I thought the furnaces just pulled "cold" air in through the front grill?
Are you sure the duct to the storage area is not a heat duct?
02-16-2012, 12:15 PM
"HAPPY CAMPER"
yes, it's a Rockwood 5th wheel 2012. I understand what you are saying, but the storage area is not insulated and yes they put a 2 inch heat duct vent in. The problem I stated was that the return air is also drawn form the storage compartment not the cabin. Suburban has said the return air has to be located in the cabin area the infomation came from them. I would hope that FR would see the problem of the installation, FR did put A 2 inch supply duct which would produce 20 to 30 cfm that alone would not heat that area to begin with let alone the oders and dirt in that area, which would be sucked in the blower and into my cabin......Thanks for you input. We will see what happens
02-16-2012, 12:32 PM
The storage area is insulated, but with all the access doors it's not insulated as well as the rest of the camper. I'm thinking that the source of the cold air return is everthing to do with the location of the furnace. In our 8280, the furnace is under the oven and the cold air return grill is under the oven door. Where is the furnace loacted in the 8289?
Dave
2008 F250 CC SB 6.8L V10
2010 Rockwood 8280WS
Nights camped in 2010 - 58, 2011 - 43, 2012 - 20
02-16-2012, 01:05 PM
"HAPPY CAMPER"
the FAU is located in the storage area under the cabin floor. I see no insulation above or in the walls of that area. The bottom of the trailer has a liner covering the bottom outside. They installed a 3/4 tall wall around the unit so the return can be sucked from the storage area back to the unit. There is no return grill located in the camper. Above the storage area where the unit is located is the bath and bedroom upfront just behind the pin box.
02-16-2012, 01:19 PM
The storage area is insulated...that's why you don't have insulation above (the bath/bedroom floor). All the exterior walls are R9 and the floor is R 12 or 14. The problem is that the access doors are only 1" thick and therefore have only maybe 3/4" insulation and are dependent on the seal around the door. That's why it's colder than the rest of the camper.
It's really strange that the furnace is installed in the camper basement...guess that's the only place they could. It's a bad idea for the reason that you've already found out.
Unfortunately, the manufacturer will probably say that the camper was designed that way and therefore, there's nothing to fix. I'd be contacting Forest River just the same.
Dave
02-16-2012, 01:31 PM
"HAPPY CAMPER"
Thanks Dave, I have done that already, the fight right now is that Suburban say's it can not take return aire from the storage area and FR say's it's O'kay. So we will see what happens. Thanks for your input
02-22-2012, 07:03 PM
Interested in the outcome/solution reached on this one. I have a 8289WS on order.
04-18-2012, 07:08 PM
Heating system
I just took delivery of a 8289WS. Is there any more information on this installation. I heard on the Flagstaff equivalent they put a return on the second stepping to the bedroom.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 298 |
| 30 members and 268 guests |
| 64c10, Areed411, bob34787, Buckeyecmpr, campfun, cardinal4fun, DAISY BOYKIN, darkcloud, deerslayer, digger47, DonCath25ds, Dunefam, gljurczyk, Hujipher, kb4srn, miatared, mjracsj, Old car, patmo2000, patrapper, ramsomair, rbrandon, rockwood06, rppatton, sail2liv, tentcamper1, transamz9, tshayn, T_LMurphy, walterw11 |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
