5" was an estimate, but very close...
Originally Posted by youroo
Our unit never had tire clearance more than (2in) above tires. It is a 34+ foot F/K V-Lite. Did they change the rubber compound in the flex axles? Is there more travel in the swing radius now? How much spacer did they place total between the (Axle plate and the Main frame)? Have they changed the (Arm angle from prior years? That is a LOT of increase in OA height,did they add another step? 5in is a Big jump from Stock! Youroo!!
As Rsbcool stated above, the U-channel spacer is at least 3". Looks almost identical in size to a 2x4 on edge. Just for the record, youroo, these are the AL-KO 4,000 lb. torsion axles. My understanding is that the original factory installation is where things went wrong, as the spacer should have been installed at the factory to achieve AL-KO's specs.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
