Old 11-09-2013, 08:46 PM   #1
SAILINGERIE's Avatar
Exclamation Rockwood 2013 windjammer tire clearance under deck
Hello all of you 2013 Rockwood Windjammer owners.
I have recently discovered a MAJOR issue with clearance between the tires and underside of the deck. By accident I noticed that my tires had rubbed through the plastic liner under the deck in the wheel wells. I called and spoke to a wonderful gentleman in the warranty department at Forest River Rockwood about this issue. I was informed that several units had been delivered early 2013 that slipped through without a riser kit installed between the axle mount and the trailer frame. This spacer kit raises the frame up about 2" to allow for proper suspension action without hitting the bottom in the wheel wells. I installed this kit with the new "D" load rated tires that run at 65psi. and WOW what a difference.
I am very impressed with the warranty response from Rockwood. Now this awesome travel trailer is even better!
2007 F-350 DRW
2013 ROCKWOOD WINDJAMMER 3006W
SAILINGERIE is offline   Reply With Quote
Old 11-09-2013, 10:43 PM   #2
Whitewolf's Avatar
Crap. I gotta wait til spring to find out as ours is in storage. Remind me in early May, will ya?
A rainy day campin' is better than a sunny day workin'.
'13 Windjammer 3025W
'14 Ram 3500 w/6.7 Cummins
No dogs. No Cats. No kids. Just us.
Whitewolf is offline   Reply With Quote
Old 11-12-2013, 07:48 AM   #3
Alleged curmudgeon
Vern's Avatar
Thanks for this information. I don't suppose you could post pictures of the before and after for us, could you?
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 11-22-2013, 11:58 AM   #4
Here is what I have.
2007 F-350 DRW
Old 11-23-2013, 09:33 PM   #5
Whitewolf's Avatar
I gotta look for some pics. I can't remember if we had that much clearance.
Old 11-23-2013, 09:55 PM   #6
Also not quite visible in these pics......I installed a 1/8" thick aluminum sheet metal cover under the deck to add some protection if a tire rubs or blows. I believe the additional clearance will be enough to keep the rubbing from happening again.
2007 F-350 DRW
Old 11-24-2013, 09:49 AM   #7
Alleged curmudgeon
Vern's Avatar
Thanks for those pics. Looks like a simple fix, which could provide some peace of mind, as mine has nowhere near that much clearance and is making me a little nervous. I take it that the fix was the spacer which is the middle piece seen in the second and third photo. This will give me something to compare mine to in the spring.
Lee
Old 11-24-2013, 07:41 PM   #8
Timex's Avatar
My tires weren't rubbing on my Vlite but I cannot put my palm between the tire and wheel well. I contacted the Flagstaff division and was told my VIN was not in the "recall" of tire clearance issues.
Timex is offline   Reply With Quote
Old 12-11-2013, 05:56 PM   #9
rip
rip's Avatar
Hello all of you 2013 Rockwood Windjammer owners. I have recently discovered a MAJOR issue with clearance between the tires and underside of the deck. By accident I noticed that my tires had rubbed through the plastic liner under the deck in the wheel wells. I called and spoke to a wonderful gentleman in the warranty department at Forest River Rockwood about this issue...
I have a 2013 Rockwood Windjammer 2809W that was ordered/built in Jan 2013. Your post made me curious, so I went out and looked at my tire clearance.
I have 1.5 inches of clearance between each tire and the fender well. This seems very tight, however I didn't see any damage yet. I don't have measurements from other owners for comparison.
Can you share the name and number of the warranty person you dealt with? I'd like to see if my new trailer is one that may need attention to prevent possible damage.
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 12-17-2013, 06:47 AM   #10
NHFire 152's Avatar
I had the same problem. My dealer installed a riser kit at the end of this past season. I have yet to tow it, but it looks a lot better.
NHFire 152 is offline   Reply With Quote
2013, rockwood, tire, windjammer, axle, tires
