Old 06-13-2013, 05:08 PM   #1
Rockwood 2109S/Tacoma hitch suggestions
I am getting ready to buy a 2014 Rockwood Mini Lite 2109S and trying to figure out which hitch to put on my Tacoma. The dealership I am leaning towards wants to put the Reese Pro Series w/d with sway control. Any other ideas I should consider? Also ideas for the brake controller too. Thanks!
Skeetzee is offline   Reply With Quote
Old 06-13-2013, 05:35 PM   #2
fonzie's Avatar
Is your Tacoma rated to pull this size of trailer?? See attached. It seems that a 2013 Tacoma can pull a max trailer of 3500 lbs, this trailer is 3624 lbs dry and max GVWR is 4769 lbs. Unless I'm missing something this is not a good match.... What is your vehicle rating?
Fonzie
Old 06-13-2013, 05:45 PM   #3
I have the TRD package and the tow package on it and it is rated to pull 6500lbs.
Old 06-13-2013, 05:55 PM   #4
fonzie's Avatar
Ouff that sounds better....I'm using a ProPride 3P hitch and love it. Others will tune in with other suggestions....happy camping. For brake controller I would go with the Prodigy P3 controller. I had it on 2004 F150 and again no issues. I now have integrated brake controller in my F250.
Brake Controllers - Tekonsha
Fonzie
Old 06-13-2013, 06:29 PM   #5
I am happy with my Equalizer 4pt hitch. Everyone has their favorites. Tekonsha is a good brand like the Fonze says.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 06-13-2013, 09:06 PM   #6
lswartz's Avatar
I would hook it up & what it does to my truck 1st. I don't need anything for my Tundra but is is a bit more truck. I have driven a 4Runner & it would need some help, I haven't driven a Tacoma so I would just be guessing.
For a previous TT I used Reese. It worked great, sway control was not needed.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 06-14-2013, 08:29 AM   #7
I don't have the same truck as you but I use the 600 lbs Equalizer hitch with that same camper. I like it because there is no sway control that needs to be disengaged before backing up.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
