Old 04-20-2018, 08:12 PM   #1
Rockwood 2306 Owners. I have a leak
Itís behind the hotwater tank and I canít see it. If I look under the camper towards the very back corner, to the right of the hot water heater if facing it. Underneath that area is leaking.
I took the wood divider off in that back outside compartment but canít see the leak because its on the other side of the hot water tank.
I actually have a Flagstaff 23LB which is the sister to the 2306. I will post in that forum also but the 2306 is more popular so I started here.
I did turn off the city water.
2018 Flagstaff Micro Lite 23LB
Equalizer 4 PT. WDH 1k/10k
2012 Jeep Grand Cherokee V8 4x4
jk70 is offline   Reply With Quote
Old 04-20-2018, 08:18 PM   #2
I don't have your model so I'm not sure of the location of the components, but if your water filter is close, check it. They are notorious for loosening or cracking if water was left in and freezing.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 04-20-2018, 08:20 PM   #3
Scoundrel
HangDiver's Avatar
To be clear, you see water leaking from underneath the camper onto the ground?
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 04-20-2018, 08:47 PM   #4
Yes. Dripping. There is an insulated part (or it seems) that is full of water on the underside of the camper. This is the far back right corner
Old 04-20-2018, 08:48 PM   #5
I can see the filter and that doesnít seem to be leaking but I will double check again in the morning
Old 04-20-2018, 09:34 PM   #6
cavie's Avatar
Does it drip only when the heater is on? Some do drip when heating. Mine does but it runs down the outside.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 04-21-2018, 07:08 AM   #7
Unfortunately not. In that back corner on the underside, itís like a water bed. I feel like I want to take a knife and slice it open to let the water out. Water has been off over night but there is still water there
Old 04-21-2018, 07:17 AM   #8
That is just the "Coroplast Cover" drill a small hole for it to drain! Youroo!!
Old 04-21-2018, 07:22 AM   #9
cavie's Avatar
you do need to drain it.
Old 04-21-2018, 08:40 AM   #10
I think the coroplast cover is the enclosed underbelly part. This is not the area. Itís closer to the edge of the camper. Material is more like a rubber sheet
2306, leak, rockwood
