Old 09-17-2012, 07:20 AM   #1
Gus
Rockwood 2501SS Cutting Hole In Super Slide
Has anyone here ever cut a hole in their super slide. I want to buy a door/hatch unit cut a hole in the side of the super slide under one of the dining bench seats, so I can access items stored under the bench seat from the outside. Does anyone have any idea of the the structural make-up of the super slide exterior wall.....i.e. wall studs, wood, metal?
Gus is offline   Reply With Quote
Old 09-17-2012, 07:37 AM   #2
lindy's Avatar
My 2604 has what you want to do. I can't help you on the structure etc, but knowing that Rockwood does do what you want on another model will give you a starting point as to where to get the door ASM. If there is a window over the table above where you want to put the door I doubt there is a frame structure there.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 09-17-2012, 08:11 AM   #3
AquaMan's Avatar
If you have a stud finder that can be calibrated to the wall of your camper, you can check for stud locations. I think you would be fine as long as you don't mess with the internal structure of the wall.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 09-17-2012, 08:13 AM   #4
TURBS's Avatar
Can't you look from the inside under the seat and see ?
Turbs
Old 09-17-2012, 08:23 AM   #5
Gus
Thanks guys I did not think about the stud finder.
Turbs, The wall is vacuume bonded, I think its like a frame, spray foam, fiberglass exterior and the inside paneling all sandwiched together. My bigest concern staying far enough away from the edge to prevent a run out crack. Thanks for any and all ideas.
Old 09-17-2012, 08:30 AM   #6
TURBS's Avatar
Aaaaaa never thought about the vacuum bonded wall .
Bad Turbs .
Good luck !
Old 09-17-2012, 08:34 AM   #7
As for "run out cracks", just make sure you radius the corners and then file or sand the corners smooth. Stress cracks will propagate from a sharp or rough cut in fiberglas.
