Old 11-02-2011, 12:54 PM   #1
Rockwood 2604 low point drain
I just got done winterizing my 2011 Rockwood 2604. I could not find the low point drain on the hot and cold water lines. The only one I could find was the water tank drain valve.
Are there low point drains on this model or not?
I order this TT in Jan 2011 and got this TT new in March of 2011.
Viper764 is offline   Reply With Quote
Old 11-02-2011, 02:44 PM   #2
Look upward in between the black & gray tank valves. Hard to find. I have a 2011 2604 & that's where they are.
2011 Rockwood 2604SS
2007 Ford F-150 5.4L
Jimmy2604SS is offline   Reply With Quote
Old 11-02-2011, 06:02 PM   #3
lindy's Avatar
Our low point drrain velves are also between the black and grey dump valaves, but they're very close to the outside edge of the trl and you'll miss them unless you slide under and look up and toward the side of the trl. I took the drain caps off and put 1/2" NPT valves in place so I could just open and close them without all the water running down my arm as I tried to take the caps off.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 11-03-2011, 11:00 AM   #4
Thanks everybody. I found the low point drains. They were not were I thought they would be. They were between the black and grey water valves but under the side trim.
Thank again.
Old 11-12-2013, 06:38 AM   #5
coastal camper's Avatar
low point drains
I'm so glad you posted this question. We are new to trailering and we knew we had to drain the low point drains but had not a clue where to find them. Thanks for the replies to the original question. Hopefully we will be able to locate them now. It's funny that all the things they show you in your walk through that that is one detail they omit.
coastal camper is offline   Reply With Quote
