Old 07-25-2016, 08:56 AM   #1
Rockwood 2604 slide problem
I have a 2015 Rockwood 2604 and my living area slide will not retract. I can do it manually but it appears to have no power. I have checked the fuses under the tongue and the auto circuit breaker in the same area. It won't work on battery or AC. I am in a camp ground with no help near by. Any ideas on what to check would be greatly appreciated.
frisbyh is offline   Reply With Quote
Old 07-26-2016, 08:46 AM   #2
AKA: 'tiredTeacher
awellis3's Avatar
I believe that the slide has two circuits. One goes from the buss under the trailer at the tongue (the one you checked) and the other is fused in the main panel. This is the controller circuit that sends power to the in/out switch.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 07-30-2016, 09:27 AM   #3
Would you let us know what the problem was?
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
2604, rockwood, slide
