Old 11-08-2019, 02:20 PM   #1
Rockwood 2703 Front panel screws backing out
Screws keep backing out. I have had to replace some of the screws with larger screws because original screws stripped out. I replaced with wood screws. What should I try next?Click image for larger version
ID:	218856Click image for larger version
ID:	218857Click image for larger version
JoeyL is offline   Reply With Quote
Old 11-08-2019, 04:04 PM   #2
Kasual Kamper
You might just want to buy a tube of Loctite and squirt a dab in each hole and then tighten the screws again.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 11-12-2019, 01:50 PM   #3
I just had the same issue. On mine(2018-2902ws), i found that the material that the screws went into was a little high and many screws just missed or hit the edge and did not bite enough. I ended up raising them just a little and screwing at an upward angel to get enough bite. Been fine for past several months
Nate
2018 Rockwood 2902WS Ultra Light
2018 Ford F-250 CCSB 6.7 PSD
Leer 100XQ truck cap
nrimshaw is offline   Reply With Quote
Old 11-13-2019, 04:52 PM   #4
I think that is some of my problem also. It appears the corner molding was allowed to sag in the middle during application, therefore the screws are not in the right place. It also appears there is air pressure built up below and behind the corner molding due to the trailer frame. Some of the gasket behind the front compartment door frame gets blown out due to pressure build up in the front compartment. Looking for a way to stop the pressure from getting under and behind the corner molding. I think the pressure getting behind the corner molding is the main reason the screws are backing out.
Old 11-13-2019, 06:25 PM   #5
Originally Posted by JoeyL View Post
Screws keep backing out. I have had to replace some of the screws with larger screws because original screws stripped out. I replaced with wood screws. What should I try next?Attachment 218856Attachment 218857Attachment 218858
If the screw holes are stripped, you could try shooting some resin in there and redrilling them.
john221us is offline   Reply With Quote
rockwood
