Old 04-09-2016, 07:59 PM   #1
Rockwood 2703 Where is the low point drain
Greetings all,
Saw another thread about the low point drain on another model and it made me realize I have no idea where mine is. There is a sticker on the side telling me where it should be but there is nothing there. Anyone know?
ondago is offline   Reply With Quote
Old 04-09-2016, 08:11 PM   #2
B and B's Avatar
Hello,
On my 2703 the drain was under the trailer by the city water fill.
B
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-10-2016, 08:44 AM   #3
I have a drain for the fresh water tank near the city water inlet, but the sticker for the low point drain is back near the sewer drain. And there is nothing there.... Maybe they forgot it!
Old 04-10-2016, 05:59 PM   #4
Crawl underneath where the stickers are and look up. I had trouble finding mine too.
bohnker is offline   Reply With Quote
Old 04-10-2016, 09:29 PM   #5
Mine is a small white valve under the trailer where that sticker is.
Marty
2016 Rockwood 2703WS Sapphire
2011 F150 Ecoboost SCAB/3.55
Martsing is offline   Reply With Quote
Old 04-10-2016, 09:35 PM   #6
B and B's Avatar
The black caps blend in with the corplast covering.
Old 04-11-2016, 11:59 AM   #7
BooBoo23's Avatar
Marty
I believe that is the fresh water tank drain, not same as a low point drain. Low point drains usually don't have a valve on them unless a previous owner has added them. They usually only have a screw on cap on the end. There are 2 low point drains, one for hot and one for cold in the same location and sometimes they will have a two different colored caps, mine are both grey caps.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 04-11-2016, 12:02 PM   #8
drojr
I have a 2016 2703WS the low point drains are right behind where the stickers are, below the fresh water fill. There are two of them, one blue (cold) and one red (hot), both are capped. you have to crawl under to find them. The small white valve mentioned earlier is the drain for the fresh water tank. As soon as the weather gets warmer I plan to put valves on both the hot and cold low point drains to make it easier to empty and blow dry with compressed air as we do cold weather camp early in the season and late in the year.
droilerjr is offline   Reply With Quote
Old 04-11-2016, 12:11 PM   #9
BooBoo23's Avatar
I've read where some people run a water line from the low points out to the side of the RV and then put a valve on it and find a way to attach it to the frame or the side. That way you don't have to crawl under it to open a valve, plus it won't be hanging down and get knocked off by something laying in the road.
Old 04-11-2016, 07:15 PM   #10
You might try to follow your lines inside the trailer, looking for any kind of a "TEE" that goes down into the floor. That's likely your low point drain.
2011 Traverse LT, 3.6L, FWD
rockwood, drain
