Old 04-14-2016, 06:47 AM   #11
leefl's Avatar
I went ahead and ordered the "Big Red" campfire, along with a 4ft pigtail quickconnect hose, and a 10ft quick connect extension hose with an on/off lever (which I hope should be good for flame adjustment)
Should all be here Friday, so may be able to test it out over the weekend, weather permitting
https://www.amazon.com/gp/aw/d/B00G258GPI/
https://www.amazon.com/gp/aw/d/B00IZCNN72/
https://www.amazon.com/gp/aw/d/B00CPYC9BC/
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 04-14-2016, 11:32 AM   #12
Originally Posted by leefl View Post
Thanks for the link. Those look ideal.
However, I don't remember there being an on/off lever on the 5er. I was just over at the storage place earlier, but didn't think to look. I'll try trawling through some old photos to see if I caught it in a photo, or if not then I'll take a look at the weekend.
An on/off lever on the outside connection on the 5er? Maybe I was reading wrong but have never seen an on/off lever on one.
The outside gas line is low pressure. If connecting something that requires a high pressure line most just remove the regulator off what they are connecting. Say you are hooking up a 2 burner Colman stove, remove the regulator from the stove and you are good to go. You use the controls on the stove as normal.
Sorry if I misread something and am off topic.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 04-14-2016, 01:13 PM   #13
leefl's Avatar
Jim
I haven't seen one either. The only on/off lever for our outside grill is on the grill propane inlet.
However, I ordered the hoses linked above, one to replace the hose with regulator that comes supplied on the campfire (which has a regulator and adjustment dial), and one as an extension for hooking into the camper quick-connect. That extension has a control lever, which should allow us to adjust the flame on the campfire.
I'll hopefully get to check it out over the weekend.
Old 04-14-2016, 01:33 PM   #14
Left Coast
The lever on the RV hose is to keep someone from seperating the quick coupler while the barbe's on....do a test...try to uncouple it with the lever on...
Old 04-14-2016, 01:59 PM   #15
leefl's Avatar
so it's a locking lever, not a flow lever ?!?
If so then I guess I need some other adjustment valve, though I guess if it shuts off the flow before allowing disconnection then in theory it should still work just fine for limiting the flow to the firepit.
Any ideas ?
Old 04-14-2016, 02:30 PM   #16
Left Coast
I went to a gas fireplace store and got the ' fix'...
Old 04-14-2016, 02:46 PM   #17
leefl's Avatar
What was the fix ?
An inline adjustment knob ? If so how/where did you attach it ?
Old 04-14-2016, 02:52 PM   #18
B and B's Avatar
Campfire in a can has a valve, standard ball valve for gas.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-14-2016, 03:26 PM   #19
leefl's Avatar
If the lever valve on the hose doesn't work (which to me looks like it should), then I'll just get a 3/8" gas ball valve, and fit it at the campfire end i guess (unless the quick-connect on the other end of the pigtail is removable)
5er, propane, rockwood
