Old 04-12-2016, 06:12 PM   #1
leefl's Avatar
Rockwood 5er outside propane connector
Can anyone tell me if the outside propane connector is high or low pressure ?
I'm interesting in getting an exterior propane "campfire"
like on of these: - Little-Red Campfire / Big-Red Campfire
and would prefer to use the onboard propane (and an extension hose/adapter), rather than carrying around a separate propane tank, but I'm not sure if that push-fit connector is high-pressure or low-pressure
(I've only used the sidekick grill twice, mostly due to bad weather on our last couple of trips)
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 04-12-2016, 06:15 PM   #2
Kaadk's Avatar
It's low pressure, so you can't use anything with a regulator.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 04-12-2016, 06:22 PM   #3
leefl's Avatar
Thanks, I guessed it might be, but appreciate the confirmation.
I guess the only two options are to either take an extra (smaller) tank with us (perhaps one of the 1 gallon / 4.5 pound ones), or put a Tee in at the tank (but then we'd have further to run the line, and would have to have the propane cabinet door open).
Alternatively, I wonder if I could replace the hose to the "campfire" with one without a regulator, but still with a similar adjustment knob ?
Old 04-12-2016, 06:33 PM   #4
Kaadk's Avatar
Sorry, had a kid meltdown to deal with, so had to cut my previous message short. To continue:
We're basically in the same boat. Since the little red's control valve is built right into the regulator there's no way to bypass it. I'm thinking along your lines were I'd like to get a separate line with just a control valve, but so far I haven't found a ready made one and I've been too pre-occupied to get the parts to make my own.
Instead, we usually either carry a spare 20# with us if we're preplanning to use it, or pull one of the 30's off the tongue when we didn't think to bring the 20 but end up needing to use the little red.
Old 04-13-2016, 12:00 PM   #5
Left Coast
Try a gas fireplace store..
Old 04-13-2016, 12:20 PM   #6
Blog: RVroadtripper.com
hbillsmith's Avatar
Just dump the hose that comes with the Reds. Replace with a regulator-less hose and use the on off lever on the RV to adjust the flame. This place has some kits:
Quick Connect Kits
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-13-2016, 12:20 PM   #7
B and B's Avatar
My Canadian designed and sold Campfire in a Can has a separate valve to control the propane flow hence the flame height.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-13-2016, 01:02 PM   #8
Kaadk's Avatar
Sounds like I got the wrong one then. But then again, when you go off to Goshen and end up camping next to boots49, and boots pulls out his little red almost every night, and your DW sees this, and then on the way home you stop by the camping world in Belleville and your DW sees the little red is on sale there, you end up coming home with a little red.
So, the moral of the story is: l blame boots49.
Old 04-13-2016, 02:17 PM   #9
leefl's Avatar
Overall I've seen better reviews of the Little Red compared to the Campfire In a Can, but I will take another look at it ... and at the link provided by hbillsmith.
BTW, I think your logic is flawless Kaadk
Old 04-13-2016, 02:23 PM   #10
leefl's Avatar
Quick Connect Kits
Thanks for the link. Those look ideal.
However, I don't remember there being an on/off lever on the 5er. I was just over at the storage place earlier, but didn't think to look. I'll try trawling through some old photos to see if I caught it in a photo, or if not then I'll take a look at the weekend.
5er, propane, rockwood
