Old 07-18-2019, 09:20 PM   #1
RFKosar's Avatar
Rockwood 5th Wheel - both air conditioners shut down
Any clues why both roof a/c’s suddenly stopped working/shut down simultaneously?
On shore power, 50 amps. Circuit breakers did not trip. Have 120vac to all other functions.
Is there another 120vac cut off device / current trip somewhere in the system?
I checked shore power and it is good. All outlets and other 120 vac appliances work (fridge, microwave, lamps). Both thermostats indicate “cool” and have fresh batteries.
The 2 a/c units just stopped working - silent.
Ideas?
RFKosar is offline   Reply With Quote
Old 07-18-2019, 10:57 PM   #2
My only response would be a flipped breaker. I would flip all off wait then flip all back on.
moose074 is offline   Reply With Quote
Old 07-19-2019, 05:49 AM   #3
Herk7769's Avatar
Low voltage can cause the thermal protection inside the motors to open due to the heat generated by the higher current draw.
Check the voltage being delivered to the camper.
Old 07-19-2019, 06:04 AM   #4
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
You say you "checked" the shore power and "it's good". Did you actually use a multi-meter to see what voltage is present at the pedestal?
You didn't say where you are camping. Is it part of the "heat dome" that has overtaken much of the country? If so, it likely could be just too much strain from too many A/C units in the RV park.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 97
rjshiflet is offline   Reply With Quote
Old 07-19-2019, 06:51 AM   #5
RFKosar's Avatar
Thanks for replies. Actually, we are camping at our home while workers renovate and repair our house. We are connected to our home’s power. The voltage is steady. I am baffled but ASSUME the problem must be inside the RV power distribution. But I certainly may be wrong because I know next to nothing about these RV sealed throwaway a/c units.
But both units go “silent”? Put fresh batteries in thermostats. Thermostats have been in use for 3 years, so they are compatible.
At house main panel, I pulled 50amp breaker and reset it. No change.
At thermostat I switched “on” each a/c fan, so fans should run without compressors, but fan is silent. Looks like no 110vac power gets to either a/c units. Will recheck breakers.
Frustrating!
Old 07-19-2019, 08:12 AM   #6
wow!
my initial thought was something in common between the two a/c's like a common thermostat. but you mentioned thermostats (plural) so i'm assuming each a/c and thermostat is independent. low voltage was mentioned as a cause of a thermal shutdown but that would be independent for each a/c motor. the fact that they shut down simultaneously says that is not the problem. it has to be something in common between the two. they should both be one their own leg of the incoming 50 amp power and they should both have their own separate branch circuit breaker.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 07-19-2019, 08:19 AM   #7
Most of the AC units use 12 VDC to run the control circuits, make sure the 12 VDC is good as well. It’s very unlikely that both system would fail simultaneously.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
Old 07-19-2019, 10:46 AM   #8
Check the 12VDC fuse to your furnace.
Most AC units (Dometic excluded) receive start power from the T-stat. The T-stat is actually just a switch. It simply turns positive (+12VDC) power on and off and the T-stat actually receives this power (+12VDC) from the furnace circuits fuse.
Dometic AC's are different beasts; their T-stats switch the ground side instead of the positive side, so the +12VDC is coming from the AC somehow; if that's what you have, troubleshooting will get more involved.
If you don't have a Dometic, and if your T-stats have the option to turn on the AC fan continuously, try that. If the fan won't run, you probably don't have +12VDC to the T-stat.
If you don't have a Dometic, you can simply take the T-stat off the wall and, using a paperclip, short the R/RC terminal to the Y terminal. This should start the compressor. Only do this for a few seconds. You can also try shorting R/RC to the GL (fan low) or GW (fan high) terminals (or just G if you don't have GL and GW). This should also start the fan.
2011 Traverse LT, 3.6L, FWD
Old 07-19-2019, 10:54 AM   #9
Frustrating!
How are you connected to your home's power?
It would be quite unusual for BOTH A/C units to quit at exactly the smae time.
You are going to need to do some voltage checks and report back.
Start with where you are plugged in and go towards the R/V checking all connections and wiring.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 07-19-2019, 11:04 AM   #10
OP stated he had 120VAC to all other functions (post #1).
Old 07-19-2019, 11:11 AM   #11
Head Rambler
I'm going to agree with Rockfordroo. Start checking the 12 volt side. While the 120 volt sides should be independent I bet the 12 volt power comes from the same place and most likely the same fuse.
Gotta go campin!
Old 07-19-2019, 02:12 PM   #12
I was troubleshooting the same situation on a friends camper one time. The furnace was next to the storage area and someone or something hit a wire on the furnace and broke it. Turned out the 12VDC went from the fuse panel to the furnace and then to the AC. The broken wire...you guessed it...it went to the AC.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 07-23-2019, 12:36 PM   #13
If its a dometic a/c there naff, how the company is still in business I don't know, all Chinese rubbish
eddy53 is offline   Reply With Quote
5th wheel, air conditioner, rockwood, wheel
