Old 11-19-2014, 05:43 PM   #51
Witch Doctor's Avatar
Originally Posted by steve819 View Post
Yes, I could install a register, but without duct work, it just lets cold air and vapors from the basement into the living area. I'm going to throw this issue to Rockwood. As another poster stated, it should not draw air from the basement, as there could be potential hazardous materials stored there. I know I have aerosol cans, disposable propane cylinders, charcoal lighter fluid, etc. stored there.
Be Careful how you word that in your manual it states do not store any of that stuff in your basement by FR. It's there legal way out. Get a hold of Suburban not FR and have them deal with it, This is the law, they have to pull R/A from the living area, Look in your suburban book it even states it in there. That is your defense. This is by Suburban not FR. That is the only legal way that forced FR to do mine. Do not listen to 1/2 this stuff look this stuff up and then go due your fight. Be ready to defend yourself. It is installed wrong with no R/A . It is against the code and law..... If you do not have the suburban manual, PM me I will copy the section and send it to you plus FR's recommendations, I have both.....Good Luck PS: Reread my post #39 I think I went through this in 2012.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-19-2014, 06:34 PM   #52
I'm Attaching suburbans note on R/A being pulled from inside living area of the coach. hope you can blow it up to read better. If you need FR about storage I have that to. look under note 1 first paragraph. Once again read my post #39. hope this helps your battle, make them due it right it your environment that you are breathing. I guess I'm just an environmentalist that doesn't want to inhale hazardous chemicals or smells, call me a radical or anything else so what.
Old 11-19-2014, 07:05 PM   #53
Thanks, as I was too lazy to go out into the cold to get the manual from the trailer.
Steve & Chris Fitzgerald
2014 Rockwood Signature Ultralite 8280WS
2006 Ram 2500 w/Cummins 5.9
steve819 is offline   Reply With Quote
Old 11-19-2014, 07:19 PM   #54
Your welcome and I was answering you on your problem only.....
280, 8280ws, fifth wheel, rockwood, water, water filter, wheel
