Old 03-16-2012, 04:42 PM   #21
Hi,I checked the clearance between the tires and it is 3" on both sides. the door side clearance from top of tire to top of wheel well is 1 1/2" and the other side is 3 1/4" and the trailer loos level in the driveway. And thanks again. It sounds like you went to alot of trouble to get some measurments for me. So two thumbs up to you.
camping is offline   Reply With Quote
Old 03-16-2012, 08:24 PM   #22
Dave_Monica's Avatar
As I mentioned in a earlier post...are the arms that the axle spindles are mounted to, horizontal on both sides. That's a big difference side to side. I doubt that I'd have 3 1/4" clearance on top of the tire with the camper jacked completely off the ground with no weight on the axles. If the arms look to be the same on both sides, I'm completely at a lose to explain the difference.
Dave
Old 03-19-2012, 02:50 PM   #23
rockwood
Ok i went out and jacked each side up and took the weight off the tires and they dropped 1 1/8" on all tires. that dosen't seem right to me. The GVRW is 4143KG or 9134LBS. Dryweight 3376KG or 7427LBS. Iam lost now. i will have to go downtown to talk to my RV guy not forest river people yet. Sa i must be forgetting something. thanks again, Brian
