Does anyone have any idea what the amp rating for the 2 circuit breakers by the battery box are? I have one, that controls the front landing gear and the bedroom slide, not working. I do not see a reset button. If it is an auto reset breaker, how does it work? Any help would be appreciated. Thanks
I have the same model, you have to feel on the very bottom of the circuit breaker (gray), there is a very small button that you need to push up on to reset the breaker. It takes some feeling to find it.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
I have a similar camper (5th wheel with 2 main slides) while I had 3 30 amp blade fuses in those holders. Two green (slides) and one black (landing Gear) all were 30 amps.
I changed them all to 30 amp automatic reset current limiters.
Make SURE you get the LONG LEG ones.
Be careful you do NOT break off any of the segmented legs!
Pop out the old fuses and CAREFULLY insert the new ones.
You will not be able to close the caps on the fuse holders with the auto reset limiters in place, so tape them in with electricians tape.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Lou.....Really enjoy your understanding and helpful insight to all the questions asked on this forum, we have a new 5th wheel and I have learned so much from you and other Forum members, its a pleasure to RV with a better understanding of some of the things that take place in these newer units.
Aw, shucks...
