Old 01-07-2016, 07:40 AM   #11
Left Coast
Cut the chain off it....it'd be portable! Oh wait...there's no pages left...
Old 01-07-2016, 09:58 AM   #12
I tried covering the vents but it didn't seem to make much difference, will get access to the Furness, in a day or two will try and change the ducting over
the old geezer is offline   Reply With Quote
Old 01-07-2016, 10:07 AM   #13
Left Coast
I was not gett'n much out of 2 of the 3 in here. Cut access hole in underbelly. found 2 hoses that had been smashed and torn when underbelly was installed...hoses had been pulled tight around holding tanks, so I replaced them. If you find that's your problem, a sheet metal shop could make a short metal pipe style connector to slip inside the bad area and add a couple screw clamps. Also, the factory hoses are thin, and loose some heat .
Old 01-07-2016, 12:32 PM   #14
Witch Doctor's Avatar
You really need to block it at the unit to produce more noticeable air flow. Do not block off more then 30% you will have limit problems. Remember these units only produce a little over 300 CFM If you just block the register you will increase your static pressure not good for the blower.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 01-07-2016, 01:43 PM   #15
They sell heater duct blockers that are 10 by 16 inch magnetic strips that you can cut to size and place over vents to detour flow to other vents. They come in white and brown and run approx. $14 for two at camping world. What's great about them is you can cut them so you can still allow a little heat in the area your blocking from.
j free is offline   Reply With Quote
Old 01-07-2016, 03:01 PM   #16
heavyodie's Avatar
The other problem I had was that the register in the hall was blowing on the thermostat. The furnace kept cycling until I blocked that vent.
heavyodie is offline   Reply With Quote
Old 01-07-2016, 03:12 PM   #17
Pickin' & Campin'
My registers were plastic so that wouldn't work for me.
I went to Lowe's and bought replacements with a dampener.
The new ones are metal but with the dampener, I don't need the magnetic mats.
That helped and I also repositioned the ducts on the furnace to improve air flow to the back of the unit.
Partially closing the one that blew on the t/stat helped too but I suspect at some point I'll have to drop the coroplast (underbelly) and see what horrors I might find there.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 01-07-2016, 07:06 PM   #18
camping baba's Avatar
The ducts lines to the bathroom and the hallway are found it the storage area .The big box stores sell vent dampers . You may have to install a solid piece of pipe to put the damper in but it is a easy install .
2013 Silverado extended cab 4x4 1500 Series
camping baba is offline   Reply With Quote
Old 01-07-2016, 10:13 PM   #19
RetiredRVer
If you're on shore power, get a couple of electric space heaters to warm your cold areas.
checkmate99 is online now   Reply With Quote
Old 01-10-2016, 09:05 PM   #20
MCTroy
[QUOTE=nomad297;1073295]We just happened to have a heavy, memory foam-type bathroom floor mat. I noticed we were getting tons of extra air in the bathroom diffuser, so I scooted the mat over a little so it covered the diffuser and it is heavy enough to completely block the air. It made a marked improvement on the flow of the other diffusers in the camper.
Bruce[/QUOTE
2x, we did the same thing with the bathroom rug. Didn't block all air flow but enough to keep the bath from being a sauna! Even the front bedroom was warm on some very chilly nights.
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
Hurry Spring 2018! We have plans ready!
MCTroy is offline   Reply With Quote
heating, rockwood
