Old 12-08-2015, 07:08 AM   #11
jtatum65's Avatar
I have a new 2013 8289WS and it too will not allow the frig door to be cracked open with the slideouts in. Although there is plenty of room on the other side of the island. I think it depends on where they place the island during assembly.
Jim & Evelyn Tatum
2013 Rockwood 8289WS FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2017 = 27
Nights Camped 2016= 33
jtatum65 is offline   Reply With Quote
Old 12-08-2015, 07:29 AM   #12
Witch Doctor's Avatar
I slit a piece of hot water 4" long wrap tubing on each door and also one on the counter in front, and close it up been doing it for 4 years. Also if you move your recliners front to front when travel I also use a piece on the shelves next to them or you will rub a whole in the back. Also protect the wall with were the handle touches it. you will rub off the wallpaper.All learned by experience....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 12-08-2015, 07:55 AM   #13
nomad297's Avatar
Would you mind being more specific? I can't picture what you're saying, but I am sure it would apply to my Windjammer 3029W, also.
Bruce
Old 12-08-2015, 08:22 AM   #14
B and B's Avatar
I have the same mark, happened going down the road. I can prop the door open after getting to storage. If i was at home i leave the slide out till fully dry with the door wide open.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 12-08-2015, 10:37 AM   #15
Bruce
My unit is a rear lounge area with two recliners. I have to move them side ways for travel and the slides to close. I like facing them front to front. The one chair handle will be against the back wall. The handle will wear a hole in the wall, you need to put something between it and the wall.
Old 12-08-2015, 11:16 AM   #16
Appalachian Ed's Avatar
Excellent tips. Y'all should charge a fee as the Forest River Help Line
Ed
2015 Rockwood 8289WS
2009 Ford F-250
Appalachian Ed is offline   Reply With Quote
Old 12-08-2015, 11:47 AM   #17
Pickin' & Campin'
We slide a piece of foam pipe insulation on our handle for travel.
We first tried a pool noodle but the hole inside wasn't large enough for it to slide down far enough to stay on during movement.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-08-2015, 12:26 PM   #18
That would work fine, I place my dogs bed there in between for storage and took care of the problem of where to stall it and protect my wall.....
Old 12-08-2015, 12:30 PM   #19
Pickin' & Campin'
Aahh... two birds... one stone!
Old 12-08-2015, 08:30 PM   #20
WFD
gljurczyk...how about the strap that holds the recliners and straps into the floor brackets..do you use that? And while on the topic how about the dinette chairs, do you strap those around the dinette table?
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
refrigerator, rockwood
