Old 02-23-2012, 09:13 PM   #1
johntoye's Avatar
Rockwood 8315BSS Questions
Recently took delivery of my trailer and was limited on time during my walk thru because of out of state delivery.
Three quick questions:
1. Where is the water filter housing located?
2. Where is the battery disconnect switch located?
3. Where is the water heater bypass located?
Thanks for your help.
John
John & Tara Toye
2011 Forest River Rockwood Signature Ultra Lite 8315BSS
2013 Chevy Avalanche
johntoye is offline   Reply With Quote
Old 02-23-2012, 10:21 PM   #2
I can't help much since I don't have your model. It may or may not have a water filter. Probably doesn't have a battery disconnect switch. that is found from the factory on motor homes and high-end campers, like the cardinal. The water heater bypass is on the back of the water heater. Usually hidden behind an access panel, sometimes under a cabinet. Find the water heater door on the outside, and then approximate where it would be inside, and start looking. you will need a square head screwdriver bit to remove screws. Lowe's has them, maybe others.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-23-2012, 10:41 PM   #3
Iggy's Avatar
Probably near the exterior water hookup. It usually is near the DC water pump.
Nope NO battery disconnect unless you install
It is located between the in and out of the water heater. You may have to look under the sink and feel for the valve.
Old 02-24-2012, 05:22 AM   #4
water filter -to right of bathroom sink bottom of linen closet. need to remove two screws to open compartment.
battery disconnect I think you are talking about is under the refrigerator its a little round chrome button that pulls in and out.
razor1025 is offline   Reply With Quote
Old 02-24-2012, 08:05 AM   #5
The water filter is under the linen closet in the bathroom as razor stated. Battery disconnect I don't believe ours came with one, but I will have to check out the chrome pull ring that razor said. As for the water heater bypass that is under the wardrobe closet in the bedroom. As with the water filter door you have to remove two screws to open door. I left the 2 screws out and installed magnetic door catches.
2009 Rockwood 8315BSS
1999 Chevy Tahoe
Pullrite Anti-Sway Hitch
nycamper is offline   Reply With Quote
Old 02-24-2012, 09:53 AM   #6
[QUOTE=johntoye;163871]Recently took delivery of my trailer and was limited on time during my walk thru because of out of state delivery.
As others have said - under the closet, to the right of the bathroom sink
not installed as a standard item
Under the kitchen sink on the rear of the water heater. you will have to remove a flimsy wooden panel to access it
NOTE: This info is for a 2010 8315BSS - 2012 might be different
...VTX-Al
VTX Al is offline   Reply With Quote
Old 02-24-2012, 01:10 PM   #7
johntoye's Avatar
Thanks everyone for your help. I will check the trailer when I go to storage this weekend.
Forest River website and brochure states that the all Windjammer & Signature Ultra Lite trailers come with the battery disconnect switch standard.
Thanks for your help!
John
John & Tara Toye
Old 02-24-2012, 01:33 PM   #8
Iggy's Avatar
My Signature doesn't have a battery disconnect. I really would like one.
Old 02-24-2012, 04:01 PM   #9
Terier's Avatar
From reading posts in the last couple of months I got the impression that FR started including a battery disconnect switch on selected units.
Iggy-
Get one installed - its well worth the investment. I have a push/push knob that is worth every penny of the high charge to have it installed by the service department.
Originally I was ok with the free little one but the tech couldn't get the battery box lid to stay on with it installed.
Old 02-24-2012, 04:11 PM   #10
Avo Farmer
MikeDett's Avatar
Thumbs up Me to on the 8315
John
I'm picking up my 8315 for RVW in Ohio March the 26th. I live in San Diego CA so I'm camping all the way home. Not sure how many changes are in the 2012-13 but I know the 2011 we looked at when makeing our decision that model did have a battery disconnect. Be sure to turn off the batteries when you put the TT in storage...
MikeDett is offline   Reply With Quote
8315bss
