Old 09-21-2013, 08:53 PM   #1
Rockwood 8328ss bedroom tv
Need advice on where & how to install TV in bedroom in rockwood 8329SS
pighitt is offline   Reply With Quote
Old 09-22-2013, 07:17 PM   #2
Take a magnet and put it on the wall where it says tv backer. The backer is a metal in the wall not wood. You can mount wherever the backer is. If you use the supplied screws that come with a tv mount you may need to cut them down as the wall is not very thick.
Drill a pilot hole and be careful not to overtighten the screws.
2013 Rockwood 8329ss
2006 Dodge Ram 1500 Quad Cab SLT 4x2 5.7L
BMWPilot is offline   Reply With Quote
Old 09-22-2013, 09:34 PM   #3
You might also try using a stud finder and then screw your tv mount into them. That's what we did for a tv mount for a 20" tv and it's worked fine.
Snardar is offline   Reply With Quote
