Old 04-14-2013, 06:37 PM   #1
Senior Moment
rockport's Avatar
Rockwood A/C Issue
Well we took out new 8289ws out this weekend for first trip, weather was great, actually was a little warm. so we ran the A\C's for the first time, I have the upgrade with the 2nd ac in the bedroom. Problem is the main A/C which I believe to be the 15k ac, does not seem to be putting out very cold air, the 13.5k ac in the bedroom was blowin and goin.. noticed on the progressive remote display when only running the main a/c shows about 10-12 amps draw .
Guess I will have to take it in and have the main ac tested. will see how good RV Wholesalers warranty network is..
Other than that everything worked great and we really enjoyed the floor plan..
rockport is offline   Reply With Quote
Old 04-14-2013, 06:40 PM   #2
Herk7769's Avatar
Sounds like the compressor is not running; just the fan. The total amps are too low for two compressors.
HAM CALLSIGN - KC3FFW
Old 04-14-2013, 06:43 PM   #3
TURBS's Avatar
X2
30 amp minimum with two a/c's goin
Old 04-14-2013, 06:55 PM   #4
QCCowboy's Avatar
Maybe to clarify, the 10-12 amps was when just the main AC was running and the second one off? If this is the case was there a difference when you had the quick cool vent open vs. running through the vents and distributing through the camper? If so you might want to check the ductwork and even how the AC is sealed up from the inside.
I have never checked the load when just the AC was running but could 10-12 be correct with nothing else but a single AC on (maybe not startup, but running)?
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-14-2013, 06:57 PM   #5
TURBS's Avatar
One a/c and converter will most likely be around 12-15 amps yes.
Old 04-14-2013, 07:04 PM   #6
QCCowboy's Avatar
So now we need clarification from the OP....it could be bad sealing of the vents. Had the same problem with last camper and with a couple dollars for aluminum tape and my time the AC worked beautifully.
2014 Sabre 36QBOK
Old 04-14-2013, 07:18 PM   #7
keven's Avatar
We the same problem with our Rockwood a/c. It ended up being the a/c had a clog which took out the compressor. FR replaced the entire a/c unit didn't even try to fix it.
keven is offline   Reply With Quote
Old 04-14-2013, 08:55 PM   #8
Senior Moment
rockport's Avatar
sorry for the confusion, yes that number was with just the main ac running, nothing else in trailer on, and hooked up to house outlet with adapter. While at the campground this weekend, had 50 amp service and with both ac's running the remote display showed line 1 about 13 amps and line 2 also 12-15 amps.. tried unit with quick cool and with ducted, the air flow seems to be there just not very cold coming from the main unit. The bedroom unit which is also ducted thru the trailer was much cooler air.. (but was quite loud).
Being hooked up to regular outlet at home, the main ac running and nothing else shows 9-10 amps only.. may not be enough power to run the 15k compressor, not sure..
Old 04-14-2013, 10:24 PM   #9
Herk7769's Avatar
That is more like it with two ACs running.
Old 04-14-2013, 10:50 PM   #10
Dave_Monica's Avatar
Sounds like a trip to the dealer is in order. Perhaps the main A/C unit is low on refrigerant as the amps says that the compressor is running but output isn't cold.
Dave
