Old 07-09-2013, 04:35 PM   #1
Owner/Operator
RodeoGeorge's Avatar
Rockwood/Flagstaff 5th Wheel Pin Box Upgrade
After much research and inquiries, I have found that the Pin Box on the Rockwood (and probably also Flagstaff) are a special build made by/for Lippert for the Ultra Light series.
The LCI Item# 2717491 (which also carries the Reese 10K Revolution Part# VHD-10K22SW) is a 10" wide Pin Box unique to these FR products. All the Ultra-Fab and Lippert Trail-Air Tri-Glide Pin boxes are either 12" or 12-1/2" wide, and replace "standard" Pin Boxes used on other 5th wheels.
I have contacted Lippert and inquired whether they will be making a Trail-Air Tri-Glide Pin Box for the Ultra Lights, but have not received a reply.
In light of recent discussion here on the forum regarding Pin Box related frame failures on other models, I'm interested in reducing the stress on the Pin Box exerted by my heavy tow vehicle.
My question is, are there any other Rockwood or Flagstaff owners that would be interested in upgrading to an air ride Pin Box?
If there is sufficient interest, that might sway Lippert in the direction of providing such a product.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 07-09-2013, 04:51 PM   #2
I thoght lip pert already did offer this.
Tri Glide Air Ride Pin Box
albuilder is offline   Reply With Quote
Old 07-09-2013, 04:55 PM   #3
Witch Doctor's Avatar
RodeoGeorge
I would be interested if it came in the revolution design please keep me informed either by the fourm or PM. Thanks Rodeo George for checking into this. I think my trailer gross weight is is like 9700 lbs. and my Reese Pin box is rated at 10,000lbs. would like one with a little more room for capacity like 1200lbs. I'm sure we have the same one even through that yours is THE Diamond Unit and mine is just the the plain #8289WS. Please keep me informed. It would be less stress on the pin box. I'm really at the max I would like something a little heaver......
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 07-09-2013, 06:04 PM   #4
Sorry disregard, did not read all of your post.
Old 07-11-2013, 02:01 PM   #5
Owner/Operator
Well, I'm in the Catch 22, ever decreasing concentric circle syndrome.
I was told by Ultra-Fab that the Pin Box was made by Lippert.
Here is the answer that I just received from Lippert:
George,
We do not have a replacement for the revolution pinbox. This pinbox is not made by Lippert.
David Bice
Looks like a drill in futility. But I tried. Does anyone have an idea?
RodeoGeorge
Old 08-07-2013, 10:51 PM   #6
Tee
Tee's Avatar
I am also interested in an air ride pin box to fit in my 8289. Don't care if it is sidewinder style or not as I still have mine locked out.
Tee is offline   Reply With Quote
Old 08-07-2013, 11:11 PM   #7
Fulltime family RVer
There turned out to not be any pin box replacements and George is looking at new air ride hitches for his truck:
Air Ride 5th Wheel Hitch
ependydad is online now   Reply With Quote
Old 08-07-2013, 11:14 PM   #8
Owner/Operator
I've spent a couple of months and untold hours searching for an Air Ride Pin Box that will fit the Rockwood series 5th wheels. The bottom line is, at this time, there is no Air Ride Pin Box that will fit the Rockwood, primarily because the OEM Pin Box is custom made for FR and is only 10" wide.
My only option to obtaining an cushioned ride is to install an Air Ride 5th Wheel Hitch. And with the height limitation of 11" in my application, I'm going to have to go with something like the TSLB2H by Trailer Saver (Hensley). Big bucks, but better than a structure repair on the RV.
RodeoGeorge
Old 08-08-2013, 04:24 AM   #9
RodeoGeorge
George, I have just finished the Rockwood Plant Tour yesterday. After reading about the Wildcat pin box failure and seen the pictures, I did talk to the plant on the pin box frame construction on our Rockwoods. They made a design change 3 or 4 years ago. I have attached the pictures of your frame. You will see the channel construction and the extra solidly welded gussets install. The pin box area is nothing like the Wildcat failure. I would not worry about a failure. You will see the pin box already installed when the Factory gets them. I had the 2 engineers that designed the Revolution by Reese at my site to inspect my pin box and the operations. They explained everything to me. There is a lot of misinformation being said on the forum, After talking to them and seeing the construction first hand, I'm not worried about a structural failure.
Name:	Factory Tour 001.jpg
ID:	37222   Click image for larger version
Name:	Factory Tour 002.jpg
ID:	37223   Click image for larger version
Name:	Factory Tour 003.jpg
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-08-2013, 08:08 AM   #10
tomjsas's Avatar
Thanks for the update...glad to see what it looks like under there. I was very worried as well but feel a bit better now! Kept thinking that every squeak I heard was the frame failing!
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
