Old 11-07-2017, 11:24 PM   #1
Rockwood Floor construction
Does anyone know when FR went back to the plywood flooring system instead of the luan sandwich? The 2018 brochure indicates plywood, but 2017 does not mention it.
urbanrescuedawg is offline   Reply With Quote
Old 11-08-2017, 10:21 AM   #2
This spring (2017) as I understand it. So 2018 models.
2011 Traverse LT, 3.6L, FWD
Old 11-08-2017, 10:31 AM   #3
This is exactly what I was told by the factory.
I will say I've seen 'photos' of what was being billed as a 2017 on the internet that had the plywood floor so maybe there were some very late 2017's that had it too. Again, this was looking at information on the'net. I did not verify in person.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 11-08-2017, 10:47 AM   #4
Brochures are NOT reliable for Info! They always have a Fine Print Disclaimer! Now for 1st hand actually "Seeing/Touching" the floors at the Rockwood plant # 10 on August of 2017 the Floors were 5/8 T & G plywood! Can't speak about the other Plants where Other Models are made! Youroo!!
Old 11-08-2017, 03:20 PM   #5
We have a 2017, built in October 2016 with the plywood floor.
rjgrady is offline   Reply With Quote
Old 11-08-2017, 03:43 PM   #6
I may have asked this before, but how do you tell the difference? I have the enclosed underbelly so.....?
Tripinbillie is offline   Reply With Quote
Old 11-08-2017, 03:52 PM   #7
In the front storage compartment I could pull up the linoleum a little and see. Also what really proved it was when I took out a panel in the compartment that was protecting some wiring and the gas line for the outside grill. The gas line comes up through the floor and the plywood is clearly seen there.
Old 11-08-2017, 04:47 PM   #8
Exact time may probably be different depending on brand (i.e., plant built).
Old 11-08-2017, 05:35 PM   #9
Remove the Front access panel from the Shower they remove "Vinyl/5/8 plywood/insulation/black membrane to make room for the Drain Trap! It shows it all,also gives the owner a chance to see if the shower pan is supported "Properly"! Youroo!!
Old 11-08-2017, 05:49 PM   #10
True,the Mini's are not built in Bld #10 so rjgrady's 2109 Mini could be plywood from another date! Youroo!!
floor, rockwood
